Kitchen Appliances - Others Logo
Question about Pitco Frialator Kitchen Appliances - Others
HAVE 3 BURNERS WHY DID I GET 4 ORFFICE
Posted by Sam craig on
When the natural gas flow to the burner slows to almost nothing is the burner bad or is it a control issue?
blocked burner or blocked orffice, or reg not giving right presure , blocked gas line check these see if it helps
All of a sudden the flow of gas seems to be next to nothing.The gastank has just been filled.
turn off tank open burners run off gas , turn off burners turn on tank very slow then try burners , if not then they should be cleaned out and check orffices see if they are blocked .
Cozy wall heater,incomplete combustion,is the flame [gas] adjustable?
try cleaning the burner and the orffice first and the air ports to the burner
1helpful
Burner is sooting when grilling with soot on the meat
clean the burner and gas orffice check to see if burner is split if so change it
May 13, 2010 • Grilling
I have a 30k btu glo warm heater how do u switch from propane to gas
change the pilot n burner orffices. they r larger than propane gas orffices. good luck
Top Pitco Frialator Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Paul Carew
Are you a Pitco Frialator Kitchen Appliances - Other Expert? Answer questions, earn points and help others
