Powerware 9120 UPS System Logo
S
SETLAK Posted on Aug 14, 2016
BATTERY DISCONNECTION MESSAGE ON POWERWARE 9120 UPS SYSTEM
POWERWARE 9120 UPS SYSTEM SNO. : RY122A0066 Serviced and Replaced 8 New 12/7 Gastom Batteries ERROR MESSAGE ON THE CONTROL PANEL : BATTERY DISCONNECTED
3 Related Answers
Anonymous
  • 197 Answers
  • Posted on Jun 16, 2008
SOURCE: Powerware 9120 UPS
yes..and that happens after a period of time. When you get new ones, check the instructions on the initial charge/discharge requirements, and use those methods. tends to help with the battery life extension.
Alan Hood
  • 195 Answers
  • Posted on Mar 03, 2009
SOURCE: I have a Powerware 9120 2000 UPS battery failure message
After you replaced the batteries did you perform a manual battery test?
If not do so.
Regards
Alan Hood
ami-man
UK
tech240
t support
  • 169 Answers
  • Posted on Sep 15, 2009
SOURCE: when the machine is power on it show disconnect
There may be a broken batt lead or a failed cell or bloc inside.
try checking with software or
take out batts and test with meter.
if you dont understand how then get a tech to help. batts are dangerous.
4answers
My ups has failured only giving an alarm indicating that batdisconnected
Check the connections on the batteries. One or more may be loose or corroded. Also check the fuse for the batteries. It may have blown.
2answers
Powerware 9120 6000i model indicates a charger failure. It is the first time that we opened this unit and we do not know the location of the charger circuit (we do not have a schematic diag). Could you...
The charger in powerware 9 series 9120 6000i ,the fan is of a quality that it fails and the heat sink does not get sufficient cooling ,it runs on 12 volt ,i replaced it with a cpu fan from a mainboard on a pc and it works perfectly now. make sure that the fan is running else the charger might go in protection or can fail due to the transistor on heat sink fails.
I ave a powerware 9120 and get a Charger failure alarm
check your batery, may it was leaked, change it with new battery
I need qty:10 from ups poweware9120
The Powerware 9120 UPS has been replaced by the Eaton 9130 (www.eaton.com/powerquality). You may be able to get some 9120 models from www.powersupersite.com. Just do a search for 9120.
2answers
Replacement fans for powerware 9120
A good electronics supplier should have. Get the correct voltage and size, and get one with the largest CFM available.
1helpful
If not do so.
Regards
Alan Hood
ami-man
UK
2answers
4answers
Pw9120-6000
1st, the 9120 is a 700, 1000, 1500, 2000, 3000, 5000 or 6000 Va
if it is a 6000 Va that voltage sounds ok, and the ups as no problem, each battery will be around 12,75 Volts, it will be higher and the charging circle ends.
UPS 9120
did u check the fuse inside the ups?
did the ups gave the error right after u replace the batteries? or some time after.
sometimes gives the message some time after and its because the charger isn´t working properly. the charger is a spare board in the 9120, 5 and 6 KVa.
good luck
Top Powerware Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a Powerware Computer and Internet Expert? Answer questions, earn points and help others
