SOURCE: Sh=kull Candy Headphones not working...
there is a possibility that the plug is not going all the way in, in the Ipod. Have you tried using other headphones on Ipod? Sometimes the plug can become unscrewed and and doesnt fit properly. It will work on some receptacles and not in others, due to differences in tolerances.
SOURCE: My skull candy skullcrushers's audio jack fell out.
Simply cutt what is left of the old plug off and buy a new plug. You will need to solder the wires on. You will find when you have baired back the cable two coloured wires and two earths. The earths fit together on the metal flange that comes out of the main body of the plug. The coloured wires go on the the two smaller flanges (left and right channels). If you get them wrong way round reverse them you won't do any damage. Make certain the earths don't come into contact with the R & L channels wires or terminals and the left or right don't touch each other. The T shaped end on the large flange is to grip the cable body, bend the tabs to grip the cable.
SOURCE: i need to replace plug on my skull candy smokin buds
the copper wires both go to the common/ground of the plug. those wires both connect to the contact that is closest to the cable. the other two connect to the other 2 contacts just pick either or.
SOURCE: The jack broke off of
There isn't really a way to fix it if that happened. Lucky you, though, you have Skull Candies! Skull Candy has a lifetime replacement program that will replace your headphones for free if you say you broke them from an accident or just from eventual wear and tear. If they were broken from obvious aggressive use, Skull Candy will still give you 50% off a replacement pair.
Requesting replacements is easy. You just answer a few questions about them, such as around when did you buy them and a short explanation of what happened, then they will send you a special box. You mail them the box back with your headphones in them, and they will send you the replacement pair!
Go here to fill out the quick replacement form!
Skull Candy Warranty
SOURCE: Which is better?
To be honest neither are that great, look at some Sennheiser headphones, They are no dearer than the banded once you mentioned but are far superior in every way, More efficient, Better quality, better construction.
