Upper thread breakage is usually caused by incorrect threading, the tension being too tight, or the thread is wrapped around the spool pin or catching somewhere in the thread path.
Remove the thread completely from the machine.
Install a brand new needle making sure it is compatible with the thread and fabric.
All About Needles
RAISE the presser foot and rethread the machine making sure it follows the correct thread path (consult the owner's manual). Verify that the bobbin is spinning the right direction in the bobbin case and the bobbin case is properly threaded.
Set the upper tension somewhere around the midway point between high & low numbers.
Retest.
If problems persist, there may be debris buildup stuck in the tension disk. Remove the thread. RAISE the presser foot, set the tension all the way to zero. Dampen a length of pearl cotton with rubbing alcohol and gently pull the pearl cotton DOWN through the tension disk a couple of times. Rethread with regular sewing thread, reset the tension to the midway point and retest.
If cleaning the tension disk does not help, then it is possible the tension disk is malfunctioning or broken. Take it for service.
thanks it helped
