Question about Lanier Office Equipment & Supplies
Lanier5365 photo copy mechine code error c27 always show when i its power on.please help me
Posted by waqaskhan on
Tommy Thomas
  • 430 Answers
Heres a good try...works 90% of the time....unplug machine for 10 mins and restart...hopfully this will clear the error...GL my friend
Posted on Aug 13, 2016
5 Related Answers
Rick Kasper
  • 2072 Answers
SOURCE: xerox error code u1-1 main motor fault
You will need to replace the main drive motor assembly.
That stepper motor is a common fail item.
You have to remove the rear cover, the MFSYS and MCU board assembly to access that motor.
Posted on Jul 09, 2008
Everett Lin
  • 990 Answers
SOURCE: How to Solve Error code SC496 for Aficio 551
hello Sir; You have to empty the waste toner bottle it located right hand side bottom, open the doorlook at "A" area you will see a big narrow plastic bottle pull out a black buckle slide out the bottle, dump the toner,the code will be disappear!
Posted on Jan 06, 2009
SOURCE: RICHO AFICIO 650 SHOW ERROR 890
The code 890 do not exist like 880 but, if it is 980? the problem can be in the hard disc...
Incorrect parameter sent to the HDD controller.
First try reset the software… press the point and numeral key simultaneously until automatically it is off the copier, several seconds can pass, the copier back on automatically. The software will have been loaded again.
If the problem persists it proves with another hard disk,
since the other possible solutions already are more complicated; these are:
· Software defective
· SBICU defective
Another problem that sometimes cause erratic errors in these copiers is that it has fallen develop in some sensor having caused short circuits that annul to some times some voltage of the power supply interrupting processes indispensable for software. Example “by developer in the ID sensor” the copier scanned but nothing more. Developer in the sensors of the feeding units produced a code 322 can seem incredible but it is thus.
For it would recommend a deep cleaning of the sectors of the image unit and everything what is under the development unit.
Posted on Sep 02, 2009
SOURCE: Aficio 551 - error code SC124
Definition- [B]
No encoder signal from the scanner motor
-Possible cause-
• Scanner motor connector defective
• Scanner motor defective
• MCU defective
• Scanner wire, timing belt, pulley out of position
• PSU defective
The screws of the pulley usually are cut that moves the scanner this causes that the car is crossed and that the sensor does not detect the home position. check and corect this defect.
Posted on Sep 13, 2009
hamzaskilltd
amir hamza
  • 318 Answers
SOURCE: error code e000002-0000 canon ir 3300
fixing assembly low temperature
Posted on Jun 26, 2010
Error 2,156,50 canon mg 2120
I found the solution for 2,156,50 error message, you can read it in the link. It worked at least for my printer (Canon MG3155)
Error code 2 2156 50 on my canon pixma MG2260 printer
Jan 17, 2013 | Canon PIXMA MG2120 Photo All-in-One Inkjet...
Show error 2200
The 2200 error code indicates that the scanner has stalled. That's why you're not able to make a copy. Please refer to this article on the Lexmark website to fix the problem:
2200 Error on the Lexmark X7100 Series All-In-One
Should the error continue to display, please don't hesitate to contact Lexmark Technical Support Center for additional assistance.
Dec 11, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
X7170 Cartridge error....Code is 1203....need to clear it....WHen I started to scan a document to fax it started getting jammed at the feed and when I stopped it and opened the top cover......It now won't...
Hi there
ERROR 1203 LEXMARK ERROR 1200 Error 1203 is an issue that occurs either when a cartridge is bad or the printer cartridge Slot is bad...
1 - try cleaning the copper contacts of the both carts and cart slot in the printer and try again..
or
2 - when error shows up, shut the printers power off; wait one minute and turn it back on press copy.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 20, 2010 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Jan 16, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
Printer 926 says error code 1203
hello
or
Nov 03, 2009 | Dell 962 Photo All-In-One InkJet Printer
H400 error
it is problem heater unite
reset code is
C photo C photo press 14 by copy quantity key press printkey then show 01 or other code press up & down key 00 press print key
Jul 27, 2009 | Sharp AR-168S Copier
Jan 06, 2009 | Ricoh Aficio 450 Copier
Error 1203
Ok this some times works.
or
Nov 20, 2008 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Copier Ricoh 1232c error code sc517
"yellow clear" then press 1 0 7 and hold down stop.. go into copy sp and enter 7 8 0 7 and then press " # " press the execute button.. when it says done power down from the red switch.. then power back up.. that will clear the error.. but you may need parts if the error returns
Oct 29, 2008 | Office Equipment & Supplies
Top Lanier Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
George Mclaughlin
Are you a Lanier Office Equipment and Supply Expert? Answer questions, earn points and help others
