Question about Daewoo Refrigerators
My Daewoo side by side refrigerator ice tray is not spinning over to release the ice how can this be remided
Posted by Richard Taylor on
Dennis
    Top Expert:
  • 1,057 Answers
First thing I would do is to try a reset. Here's a YouTube video showing how to do this: Daewoo How to Reset the Ice Maker American Style Fridge Freezer
and here's a generic "how to" guide on troubleshooting and repairing most types of refrigerator ice makers.
Ice Maker Troubleshooting Guide
Posted on Aug 13, 2016
5 Related Answers
Anonymous
  • 213 Answers
SOURCE: Ice sticking to ice maker
the water valve in the back where the water line conects is not letting the right amout of water pressure up to the ice maker. either valve is bad or if you have a filter it may need changing
Posted on Nov 20, 2007
Anonymous
SOURCE: LG LRSC 26923TT Side by Side Refrigerator Problem with ice maker
We have the same problem with the ice cube tray. Repairman said the tray must be replaced every year as continual bending warps it out of shape. Replace every year and your problem is solved.
Posted on Mar 08, 2009
ginko
Ginko
  • 19396 Answers
SOURCE: Ice Maker will not release the frozen ice cubes from tray
The icemaker use an avaporator system with an heatinc coil and a fan to release cubes.
In your case either the heating coil or the fan in the icemaker must be replaced.
parts can be purchased from partselect.com.
Posted on May 31, 2009
Joe Hogan
  • 10865 Answers
SOURCE: water does not fill ice tray GE refridgerator
Hi Alice. If I was nearby I would stop by and take a look for you but since we are cyber only I will assist you and yes, you can fix this yourself!
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Aug 15, 2009
Anonymous
SOURCE: Admiral Refrigerator makes hollow ice
If your filter is over 6 months old, try replacing it first. Its time for a new filter anyway. Thats when I usually know its time for a new filter.
Posted on Dec 30, 2009
Water not filling the ice tray
locate the water fill valve,wiggle the connections to it as to clean these connections,then manually fill the ice maker with approximately 4 oz. of water,sometimes this will kick start the ice maker and it may take over from there
Jan 31, 2013 | Daewoo FRSU20IC (21.8 cu. ft.) Side by...
I took out the ice tray and it looks like the drive mechanism inside the frig that interlocks with the tray needs to spin counter clockwise to release cubes and clockwise to chop the ice. No matter which...
The first place I would check is the solenoid listed as position 33 here=> MSD2756GEW Ice Bin and Components When switched to crushed to not crushed that activates the shifting lever to create crushed. First unplug refrigerator and then unplug the coil and check resistance with an OHM meter. When energized with 120 VAC the coil should pull a strong magnetic field through the center. Give that a try first. Part is=> 61005253 SOLENOID
sea_breeze_136.jpgCrushed-Cubed Ice Solenoid
Let me know what you find, Thanks, Sea Breeze
Apr 13, 2011 | Maytag MSD2756G Side by Side Refrigerator
My ice tray moves fine and makes ice but for some reason it won't release the ice when it turns. Then the water tries to fill up over the full tray and makes a big mess. Any suggestions?
Either the icemaker support is broken, DA61-02205A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, DA63-01453B
Good luck,
Vlad
First Choice Appliance
Jan 11, 2011 | Samsung RS2534 Side by Side Refrigerator
Samsung Intellect Side by side Refrigerator/Freezer ice maker making ice but not releasing cubes.
Either the icemaker support is broken, DA61-01801A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray catches the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, DA63-02284B
Good luck,
Vlad
Dec 05, 2010 | Samsung RS2630SH Side by Side Refrigerator
The ice maker in my samsung fridge is putting too much water into the ice tray thus dripping water into the ice compartment and freezing all the ice cubes together and dripping through the outlet
Either the icemaker support is broken, DA61-02205A or the ice tray is damaged or has lime buildup. The ice tray is supposed to twist when it flips: an off-center stud on the tray is supposed to catch the support, while the tray is still turning. If it does twist but does not release ice - replace or clean the ice tray, DA63-01453B
Good luck,
Vlad
Jul 17, 2010 | Samsung RS2578BB Side by Side Refrigerator
Ice not releasing from Ice Trays
Spray trays with pam. Usually does the trick
Dec 26, 2017 | GE GSS25JEM Side by Side Refrigerator
Ice maker not working has frozen ice inside tray and had cubes on top it's just no longer moving
remove tray, ice may be frozen around auger or gear that spins auger, dump all ice and start over making ice. also, wile tray is out hi dispense switch and see if grer spiindle rotates, if not ur motor has gone bad
May 22, 2010 | Kenmore 53603 / 53606 Stainless Steel Side...
May 31, 2009 | Maytag MSD2454G Side by Side Refrigerator
Ice maker on side by side
Spray your ice maker tray with pam. Ice maker trays build ups from water so occasionally spray them with pam and they will dump okay.
Jul 30, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
358 people viewed this question
Top Daewoo Refrigerators Experts
Lawrence Oravetz
NOEL
NOEL
Are you a Daewoo Refrigerator Expert? Answer questions, earn points and help others
