SOURCE: makita ls1013fl I need instructions on how to install
I installed it by looking at the parts pictures in the manual and experimenting. Thanks for the try at helping me.
Joe
SOURCE: I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
SOURCE: can't get the handle of a mastercraft compound mitre saw to open
If you look on the left side of the saw near where you see that it pivots to go up and down. You will see some type of knob that you can pull out...you will need to push down on the saw handle to allow this to happen.
Hope this helps,
RSMITH972278
P.S. PLEASE RATE MY ASSISTANCE
Testimonial: "thanks, got it working."
SOURCE: Mastercraft Maximum Compound Mitre Saw
Mastercraft's help line is 1-800-689-9928. However this saw is no longer in production and parts are available only until stock is depleted. It was supplied by an european company called WMH Tool Group that apparently doesn't supply CTC any longer.
SOURCE: blade guard for Ryobi 254mm Slide Compound Mitre
Try at eReplacementParts.com : Power Tool Parts and Tool Repair Diagrams or ToolPartsDirect.com - Your Tool Repair Supply Store.
If you need more help come back.Post / thumbs / testimonial are welcome!
