Haier Dishwasher DWL7075MBS has blinking lights Sanitize Rinse, Heated Dry, and Start/Reset; also child lock blinking. Cannot get response from ANY button, including reset.
Will not respond to anything. Blinking lights on Sanitize Rinse, Heated Dry, and Start/Reset, also child lock blinking. No response on any button. Will not start.
Try finding the electrical circuit that powers your dishwasher. Turn off the breaker for a while (15-30 min.) This may reset the computer to factory defaults.
Open the door.
Within 3 seconds press the following sequence --Try pressing normal wash,
heated dry, normal wash, heated dry, normal wash, heated dry three times within
6 seconds and then press cancel to reset the dishwasher. If that doesn't help
then try pressing Saini
Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air
Dry, Saini
Rinse, Air Dry, Saini
Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door
and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally.
If the light is still blinking try and reset the power to the dishwasher and
try again. If still the light is blinking then check for the connections on the
keypad, it may be due to moisture or shorted connections on keypad.
Hope this
helps... Please post back if you need more information.
Hi Open the door.
Dry, Saini
and press Cancel.
keypad, it may be due to moisture or shorted connections on keypad. Hope this
helps... Please post back if you need more information. Daniel
Open the door.
Dry, Saini
and press Cancel.
Hope this
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry,Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel. Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad.
Hope this helps... Please post back if you need more information.
Door latch. Open and close the door to make sure the door latch is securely fastened
Hi-Temp Wash, Hi-Temp Rinse, or Sanitize options. Some models have options that may require a water heating delay, such as Hi-Temp Wash, Hi-Temp Rinse, or Sanitize. Additional time may be required to heat the water to the proper temperature. The dishwasher will continue to circulate water during this heating delay but the timer will not advance until the proper temperature is reached
Unlock your Kenmore dishwasher control panel by pressing and holding the "Heated Dry" button for four seconds.
Press a series of four buttons in quick succession. Press "Heated Dry,"
"Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore
dishwasher to run a short diagnostic test
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its
diagnostic test. This should reset your dishwasher control panel and
stop the "Clean" light from blinking repeatedly.
Good luck.
silly question but did you try holding the control lock button(perhaps its the heated dry button) in for 3 secs???? sonds as if the CONTROL LOCK has benn activated( child lockout)
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
