Exercise & Fitness Logo
Ruschda Kariel Posted on Aug 11, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi i have a Trojan voyger treadmill and it wont start. The motor wont turn and the treadmill it shows e7 and e6. Also how do i calibrate this machine? Thanks Saleem.
Electro Med Services
Level 3:
  • Master 6,694 Answers
  • Posted on Aug 15, 2016
Master
Level 3:
Answers
6694
Questions
Helped
1870995
Points
21433
I'd you wish to get some details about treadmill error messages and repair then check the following link
http://electro-medical.blogspot.com/
On my Cardiozone treadmill, I hit the Mode button by mistake (have never used it), now all I get is an E7 error message with the number 22 or 23 to the right of it.
Try pressing the Mode button again until the error message goes, or disconnect from the mains or remove batteries to reset.
How do I fix E7 error on treadmill?
E6 or E7
  1. Turn the power OFF, wait 5-seconds and turn back ON.
  2. Get into test mode and enter through the I/O testing step. ...
  3. Once the unit is in the mid-level position, power the treadmill off for 5-seconds and then power it back ON.
  4. Start the treadmill.
https://www.google.com/search?q=cardiozone+treadmill+e7+error
I have an Accomplish Inspiration treadmill showing a E7 code could you please advise of a solution
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range.
Hopefully, you have a manual that will show you how to make this adjustment. If not, search online for free online manuals for your model.
I have strength master treadmill when I put in on it show me E7 please what is the problem
An E6 or E7 error code is an incline error code. The E7 code means the potentiometer value the console is reading from the lift motor is out of range. This can happen when there is a bad wire harness connection or a damaged wire harness. It could also just mean the incline motor needs to be adjusted back into range. If all wire connections look ok, the incline motor will need to be adjusted.
I’m happy to help further over the phone at https://www.6ya.com/expert/charles_6bf94c079488b145
Error code message
What Does Your Treadmill's Error Code Mean? - LifeSpan
www.lifespanfitness.com/.../what-does-your-treadmills-error-code-mean
Free
May 21, 2015 - If the running belt stops after 6 seconds of starting the treadmill, this may indicate that either the ... If there is no belt movement, or you notice a burning smell coming from the motor area, this ... An E6 or E7 error code is an incline error code. ... This will cause the incline motor to raise the running deck up.
[PDF]ERROR CODES: ADDITIONAL ERROR CODES:
www.gympart.com/TSB/.../Treadmills/.../Sportsart%20Error%20Codes.p...
ERROR 6: INCLINE ERROR - CHECK INCLINE OPERATION AND CALIBRATION. ERROR ... ERROR 1-1: AC SERVO ERROR - AC SERVO MOTOR ENCODER HAS FAILED ... error codes listed by category: treadmills, bikes, elliptical trainers. ...ERR1 Condition 1: Press speed key; walk belt doesn't move; ERR1 appears.
[PDF]Error Code Troubleshooting Guide
My tx500 has a e7 on display and wont start what can i do
Dear Sir:
has 2 options this error:
1) elevation motor: a) motor faulty b) grease and lube the gear c) adjust the potentiomenter d) gear and bars lube e) main motor board faulty. see my personal TIPS FOR HELp.
2) see the attached diagram for adjust the reed swithc, clean, and tight the ribbon cable from keypad , and tight the connector from display board vs lower board. b) the display boad can be faulty.
In short after you did the adjustment,RUN INMEDIATELY, the software calibration for diagnose and troubleshooting.
5helpful
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
3helpful
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
Top Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
john h
ADMIN Andrew
ADMIN Andrew
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
