Question about LG Televison & Video
LG 55" TV model # 55LK520UA chassis # AUSYLJR. Screen comes on several seconds (shows OSD info) then the set shuts down and then the red power LED is blinking. I'm an EET, but not primarily a TV guy.
Posted by William Miller on
  • William Miller
    William Miller May 25, 2017
    It turned out to be the master inverter board # 6632L-0613A (on the left side of the set when looking from the rear with the back off) but it could have just as easily been the slave inverter board # 6632L-0614A on the right side.
    Just to be safe, I bought both used on eBay for about $5 each with free shipping. I swamped the master board, then tried it, and it was fixed. I kept the other board for next time.
    This was advertised as a Vizio brand on the eBay listing, so apparently these boards fit many different brands or more than one at least.
  • William Miller
    * swapped, not swamped lol
Sattech
  • 22 Answers
Ahoy there...Your case would appear to be the classic dying cold cathode tube(s) . After a long service the tubes will grow a carbon track down the tube and it won't take much length to cause an increase in current from high voltage unit . This current is detected and unit shuts down . They can be sourced and replaced , I have seen them from American sources for approx. $30 for 10 40 inch .
HOWEVER I have also watched an LED conversion on youtube which may be a smarter choice as the rest of the tubes will meet that fate sometime . It is a picky , tedious dangerous(to your screen not you so much) process .
If you are mechanically adept and don't use force on the flat wires(there should be ZIF sockets or a stiffened handle , be careful)
you stand as good chance . You need a good sized work space though .
Good luck
Hugh
Posted on Aug 11, 2016
1 Related Answer
Ecollier2012
Edward
  • 3459 Answers
SOURCE: Hitachi 50ux58b
If you have Hitachi model number 50UX58B, 60UX58B, 50UX58K, 60UX58K, 50SBX78B or 60SBX78B and you have the following symptoms you may want to grab a repair kit from www.TvRepairKits.com. They have put together a kit that includes the parts and instructions to fix these models. This is a fairly common problem with the above model numbers. It is typically caused by a blown capacitor and pico fuse. Again, you can get a kit from the above address.
Here are the symptoms...
Primary Symptom: No Audio or Video. Power light will come on briefly then shut off.
Other Possible Symptoms : The green LEDs on the circuit board light up for a few seconds then turn off.
Hope this helps,
Posted on Nov 07, 2008
Video blanks out, power light turns off, power supply shut down
There are bad capcitors in the control board, there are bad tact switches on the control board,or the CRTs are leaking fluid onto the printed circuit boards Good Luck
Jun 21, 2007 | Hitachi 61HDX98B 61" Rear Projection...
Ive got a LG 55" LED tv model #55LA6200 it will turn on and show the LG screen then goes black after a few seconds. Audio works and i can see the screen with flashlight which part do i need.
This could be the power supply at 55 dollars or the LED back light strips that are about 80. Unless you know how to test them, it is a toss up. Most of the time it is the led strips though. http://www.shopjimmy.com/lg/55la6200-ua
Feb 22, 2017 | LG Televison & Video
Picture freezes then shuts off and restarts.
First of all, shame on LG for not providing support on their product. It sounds like this TV isn't that old. I was just bragging on them to several people this week. Your symptoms sounds like a main board issue. But in order to be sure, proper troubleshooting will need to be done to pinpoint the problem. You will have to pay a diagnosis fee, usually $75 range, but for a 55" late model set, I would say it is worth the money. So sorry to hear this, I'm hearing so many of these late model LED TV's failing left and right.
Nov 21, 2012 | LG 55LE5400 55-Inch 1080p 120 Hz LED HDTV...
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Power up Problem
my hitachi model number:55fx48b suddenly just stopped. I can unplug the tv, then turn it back on and red led light will come on for 2 seconds and shuts back off! Can you please help me
Jun 28, 2008 | Hitachi 55FX48B 55" Rear Projection...
The TV is a Phillips Matchline 55"; wide screen, approx 7 years old.When switched on the LED goes red then there is a clicking sound then the LED blinks red continuosly and there is no picture.
The TV is going into protective shutdown. What is the model number of your set? I may be able to help you depending on the chassis number.
Mar 13, 2008 | Televison & Video
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Televison & Video Logo
126 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
Marvin
Marvin
