Question about Electrolux Freezers
I defrosted my Electrolux intuition chest freezer yesterday and the red warning triangle on the lid won't stop flashing now. Why?
Posted by Amanda Ross on
Marvin
    Top Expert:
  • Electrolux Master
  • 85,239 Answers
Check the temperature inside the freezer, chances are it just is letting you know it hasn't reached the correct temperature yet.
Posted on Aug 11, 2016
1 Related Answer
jason zeringue
  • 141 Answers
SOURCE: I have an Electrolux Intuition Chest Freezer. The
you need to clean the condensor coils with a brush or compressed air
Posted on Oct 01, 2010
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
What does the red warning light by the triangle mean on a blomberg
Under normal operating conditions, the internal
temperature of the freezer will ensure the longterm
conservation of the stored food.
When such temperature rises above a certain
level (-12 °C), the appliance will trigger an
acoustic and light alarm. The light alarm is a
blink red light (Red Alarm Indicator Light), while
the acoustic alarm is an intermittent sound.
You can stop the acoustic alarm by pressing
the Acoustic Signal Stop Switch once.
When switching on the freezer for the first
time, the Red Alarm Indicator Light will
blink until the internal temperature has reached
a level required for the safe conservation of frozen
food.
Dado
May 28, 2014 | Zanussi 10.31 cu. ft. / 292 liter Chest...
How do you activate the flash defrost function on a Kenmore 16082 model? I can't find any flash defrost button.
Hi
Not all these models were fitted with a flash defrost plunger, if fitted it is inside the lid on the left hand side.
You will need to remove all the product from the freezer and store it elsewhere.
1. Pull out the flash defrost button
2. Put a chock of wood or similar to prevent the lid from closing (if the lid closes it will stop the flash defrost)
3. Wait until all the ice has melted then clean out the casing, some of these models have a drain plug in the base, (put a shallow tray under the outlet to catch the water) others you will need to mop out the water.
4. Push in the flash defrost button and wait for a couple of hours and then you can reload the freezer.
If there is no flash defrost button then follow the above instructions after you have emptied the freezer, all you need to do is switch off and unplug the freezer then go to 2. above. When finished plug back in and reload.
Regards
Gordon
May 05, 2011 | Kenmore Chest Freezer 16082
RED TRIANGLE LIGHT STAYS ON CHEST FREEZER IS 10
defrost cycle is innactive, will ice up shortly and may not turn compressor off, defrost the unit totally(Turn off for 2 days with door open) and remove all water from the unit once done. Restart unit and should work normal for a week or so, ie...defrost cycle...get back to me if this is the case and will sort it from there, [email protected] Russ
Mar 28, 2011 | Whirlpool Freezers
I am defrosting my chest freezer and have the lid open and water is continuing to drip out of the lid. Why?
condensation has frozen inside your lid and now is defrosting and driping out. Reason : there is a air leak in the lid
Jan 09, 2010 | Frigidaire 12.8 cu. ft. Chest Freezer...
Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
May 26, 2007 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Freezers Logo
275 people viewed this question
Top Electrolux Freezers Experts
Dennis Boxerman
washington munene
Level 1 Expert
ray gallant
Are you an Electrolux Freezer Expert? Answer questions, earn points and help others
