Question about Smeg Cooktops
I want to replace an ignition candle on a Smeg cooktop P1752XA.
Top left burner does not ignite anymore and Ive been told the ignition candle could be the cause.
Posted by Mick Grollo on
5 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: Romvoing the top of my Whirlpool Cooktop
first thing is the spark module(ignitor-- your referring to) is probably good and your electrodes are damaged. more then likely the problem. when you turn on one burner they should all spark( 1 module controls all 5 electrodes) so lets check that, first. when you turn on any/all burners do you at least hear clicking??. theres a switch under each **** that turns on the spark(erhaps one of them is bad. think of the electrodes as spark plugs on a car, they spark the same way, ck to see that they are clean(free from rust and carbon build up).using emory cloth or a woman's finger nail file try "sanding" down to a shiny surface the very tip of the electrode protruding out of the burner head.look for cracks in the porcelin housing around the electrodes this will lead to miss fires of the electrodes
Posted on Mar 12, 2008
jason
  • 905 Answers
SOURCE: Jenn-Air JDG8430 Ignitor won't stop sparking after burner ignites
when you turn the dial a switch is engaged to start the ignitor , or if there is a sensor(one for the two bottom , one for the two top , it may not be reconizing that they are lit ,or the problem is sticky switch in the the dials, but I believe its a sensor that detects both of those burners that stops the spark
Posted on Oct 20, 2008
gerbee gomez
  • 222 Answers
SOURCE: Ticking sound of gas igniter continues after off.
try to clean the place wen u remove the control knob,by using a vacium.
Posted on Dec 02, 2008
Anonymous
  • 338 Answers
SOURCE: old Thermador cooktop continues to spark even after turned off
sounds like you have a bad switch. maybe on the large burner.. some of those switches can be replaced without the whole harness.
Posted on Dec 22, 2008
Anonymous
SOURCE: stove top ignition doesn't stop ticking
My Dacor cooktop had a similar problem of continuously clicking igniters. I unplugged it a couple months ago and used a piezoelectric igniter to get it started. Then I looked in the Dacor FAQ and it said to clean the ceramic igniter posts with alcohol not water. I had to scrape some gunk off a couple of the posts with a knife before cleaning with alcohol. Now it works.'
I think the igniters use electrical conductivity to detect when they need to spark, so even slight invisible contamination on the igniter insulator can confuse the sensing system. Also they all seem to fire as a group, so all of them need to be clean because if any one of them is dirty then they will all malfunction.
Posted on Jan 04, 2010
One of my igniter in my smeg gas cook top does not spark
Here is a tip that I wrote to give details about why your cooktop will notspark to light the burners..
Cooktop Range Stove spark ignition does not work
heatman101
Aug 30, 2011 | Smeg 23 in. SE64 Gas Cooktop
My smeg cooker is brand new! after cleaning it - one of the rings will not ignite properly, it clicks so gas is coming through but no flame! any sugestions?
Brand new means you have a warranty, get the service agent to check.
I have found that you can easily place the wrong burner cap on the incorrect burner ring(the smaller burner caps).
Could also be dirt or water in burner ring or the burner jet(use needle to clear jet).
Are sparks coming from all ignitors? You might have damaged the spark plug.
May 01, 2010 | Smeg 23 in. SE64 Gas Cooktop
Ignighter is not working on any burners
if if does not light anymore you have a ignition sequence fault could be a faulty switch foe the ignition pcb ht lead or electrodes
Aug 21, 2009 | Smeg HB96CSS Gas Cooktop
Thermadore cooktop SGCS365RS
if its one of the center burners witch has the auto on off for extra low its the moduel under the handle
Potentiometer
Jul 19, 2008 | Thermador SGS36GS Gas Cooktop
Stuck auto ignition
try easing each knob upwards a bit.
Jul 15, 2008 | Smeg 23 in. SE64 Gas Cooktop
Smeg SAR134A/X does not ignite.
give it a while for the switches to dry if it doesnt start working then reply to me most of the time they will start working also check to make sure the breaker didnt trip
Mar 18, 2008 | Smeg 23 in. SE64 Gas Cooktop
Burner fails to ignite
I have this cooktop and it is hands-down the worst. That clicking sound is the spark missing the mark because of a crack or chip in the ceramic igniter. Damage is caused by the ceramic heating too quickly. Especially when the house is cooler in winter, or in air conditioning. I had a Jenn Air repair guy in to replace them before the warranty ran out and he said this happens with every single one of these models with the ceramic igniter. Also, one of the knobs on the front by the medium burner got so hot it melted. He gave us a new one. He had a whole box of them in his truck! He told us the design was inferior and that Jenn Air uses a different igniter for higher end models because of this problem, but won't re-engineer the lower end units because it's cost prohibitive. Even with the repairs they cover for the first year, they recoup in charging for service the second year, than profit on the repair and/or replacement charges for the parts every year after that. All the parts sold are OEM--no after markets, so, at roughly $27 a pop for each igniter, they make out pretty good. Oh, and the burner knob is melted again. What a bunch of scamsters. I will never give them my money again and am shopping for a new cooktop. I left a good review at bizrate for this cooktop.
May 18, 2007 | Jenn-Air JGC8536 Gas Cooktop
Cooktops Logo
891 people viewed this question
Top Smeg Cooktops Experts
Jorgie Navito
Jorgie Navito
ray gallant
Bill Boyd
Are you a Smeg Cooktop Expert? Answer questions, earn points and help others
