SOURCE: Epson printer says "cannot recognize ink cartridges".
Are you using genuine epson cartridges? Many generics simply dont work on the newer printers. Once the printer decides the cartridge is empty, it sends a signal to the chip and that's it. You might hear ink, but if the chip says empty you can't use it. It also has the annoying habit of doing this when there's still 10-15% of the ink left.
I use reusable cartridges from http://www.ccs-digital.com They hold 2/3 more ink and the chips automatically reset to full if you remove and re-insert the cartridge. Instead of replacing the entire cartridge when it's empty, you pop out an internal ink tank and replace just that. So you know the chip has already been recognized by your printer. The ink tanks cost under $3. I think these are a brilliant invention.
SOURCE: Epson workforce 600 continue to
If this message appears when you turn the printer on it will need a repair, this will be down to a sensor fault.
If this message appears when you try to print Check you are using the correct paper type and size settings, on the printer if being used standalone or via the printer driver if using via a computer.
Also try using a different paper type and brand ideally Epson paper as it is an Epson printer. If the fault continues the printer will need a service.
As this printer was released this year you should be covered by some form of warranty, contact Epson for a service.
SOURCE: epson workforce 600 displays message
Error 600
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
SOURCE: I'm trying to install my new Epson Workforce 520
If you are using the Windows Vista or Windows 7 Operating System, please disable UAC Feature from Control Panel.
You can Re-Download the Driver from the following link:
http://www.epson.com/cgi-bin/Store/support/Supportdlsurvey.jsp?BV_UseBVCookie=yes&download=ftp%3a%2f%2fftp.epson.com%2fdrivers%2fepson13779.exe&pn=WorkForce+520&pc=Epson+WorkForce%26%230153%3b+Series&ft=driver&returnpage=%2fsupport%2fsupDetail.jsp&returnparams=%26infoType%3dDownloads%26oid%3d152503%26prodoid%3d63087903&licenseoid=17774
Enter your Email details go ahead with download process.
Then install the Driver.
