Question about Food Processors
Can I get replacement jars for my Bullet - Food Processors
Posted by Linda Freedland on
How to use 'magic bullet to go' without magic bullet battery?
Try us with that battery number, Sylvia. We may be able to find you a replacement battery.
That's a... cordless food processor???
Aug 13, 2014 | Food Processors
Can you replace a melted cord
I posted the reply pasted below on how to take the Bullet apart - really not difficult once you know where the hidden screws are apart. Once apart it easy to see where the power cable terminates and should be easily possible to connect in a new cable in its place.
Yes its easy to take the Magic Bullet apart.
1. First pry out the 4 black rubber feet on the base with small screwdriver and unscrew the 4 cross head screws revealed below.
2. Remove this black base to reveal the inner black base Unscrew the cable clamp - 2 screws and the 3 screws that retain the remaining black base to the body of the bullet - slide it off over the power cable.
3. Turn the bullet the proper way up and pry out the 3 white rubber bumpers with a screw driver blade that are set inside for the cup to rest on - each is located with two rubber pins. Once all 3 are removed you will reveal 3 more cross head screws - these countersunk - remove all 3 and then the internal motor will be free to lift out through the top of the Bullet casing.
4. Its possible to slip out the 3 white plastic sliders - taking care to note how they seat each on a small spring to cleanup both the slides and the sliders.
To re assemble step by step in reverse - noting to align the motor cable with the cutouts on the bullet base.
Aug 22, 2012 | As Seen On TV Magic Bullet Food Processor
Where to buy a magic bullet base gear?
Hi Pamela... Magic bullet base gears can be purchased from amazon (my recommendation). Enter this link Healthy Blend of Power Precision and Value and choose carefully which one fits (by shape, size, price etc). I hope this was helpful. enjoy
Jan 15, 2012 | As Seen On TV Magic Bullet Food Processor
I need help finding magic bullet instructions manual
A Manual for the Bullet 10 can be found online here:
http://kitchen.manualsonline.com/manuals/mfg/magic_bullet/electric_blender.html?idRes=519999
The Magic Bullet website also has A fFequntly Asked Questions section as well as a Recipe page that you may find useful:
http://www.buythebullet.com/faq.php
Oct 19, 2011 | As Seen On TV Magic Bullet Food Processor
I need replacement parts
Searching eBay right now brings up several replacement parts listings, as well as one Magic Bullet being sold for parts or repair, currently only at 99 cents.
You can also contact Homeland Housewares (the company that makes the Magic Bullet) to find out about replacement part pricing and availability.
Hope that helps!
Sep 29, 2010 | As Seen On TV Magic Bullet Food Processor
My magic bullet wont spin. It makes the noise but does nothing?
Your black plastic blades, which are on the bottom of the black blade attachment, that interlock with the blades on the base of the machine may be worn down. When the bullet is turned on and these are not interlocked properly they rub on each other causing the interlocking part to wear down so it no longer catches to turn the blades. As far as I know the only solution for this is to get a replacement part.
Dec 13, 2009 | As Seen On TV Magic Bullet Food Processor
Blade is broken can i get new blade
On the website they are offering a package where you can get a new blade, but it comes with a bunch of other things. The website is: http://www.buythebullet.com/
and this is the package they offer:
Deluxe Upgrade Kit Upgrade your Magic Bullet! You can save even more time and trouble in the kitchen with the Magic Bullet Deluxe package, which includes 2 additional Tall Bullet Cups and 1 additional Short Bullet Cup, plus 3 more Stay-Fresh Re-sealable Lids.
Using the Magic Bullet in our own homes we've found these extra Bullet Cups and Lids come in very handy when the others are being used to store leftovers in the fridge. Plus, you also get 1 extra Cross Blade. And since this is the blade you'll use the most, it's nice to have an extra one around when the other is in the dishwasher. If you have a family at home, the Magic Bullet Deluxe is a must! Upgrade your Magic Bullet today for just one payment of $29.97 (plus $6.99 shipping and handling).
Nov 26, 2009 | As Seen On TV Magic Bullet Food Processor
My magic bullet stops rotating
The Magic Bullet power base is designed with HIGH TORQUE MOTORS and it is NOT TO BE USED FOR MORE THAN A MINUTE PER USE.Otherwise its gonna last a long time. You need to buy a new one or a refurbished one. Search google with keywords "amazon magic bullet power base".
Aug 13, 2009 | As Seen On TV Magic Bullet Food Processor
Food Processors Logo
521 people viewed this question
Top Food Processors Experts
Tom Chichester
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Food Processor Expert? Answer questions, earn points and help others
