Sorry but I can't help with a diagram.
I think your car could be a CANbus system where there is no direct connection between the starter switch and the starter motor. Starting is likely to be controlled by a relay which is energised by an ECU if the immobiliser has been disarmed, the starter switch only serving to send a signal to a nearby computer for starting to take place.
If this is your system it is possible to check the switch, relay, starter in the traditional manner but glitches in the system will need specialist diagnostic equipment to locate.
Apologies if I have guessed wrongly...
SOURCE: Rough Ideal on 2004 Ford Explorer
Open hood and listen for vacuum leak sound. pcv hose is most likley cause.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/terry_db4da071b7da3ac1
SOURCE: 2004 Ford Explorer won't start. Think we need to
it resets itself.
Principles of Operation
The PATS uses a specially encoded ignition key. Each encoded ignition key contains a permanently installed electronic device called a transponder. Each transponder contains a unique electronic identification code out of over 18 billion, billion combinations.
The passive anti-theft system (PATS), also known as SecuriLock ®, uses radio frequency identification technology to deter a drive-away theft. This system is known as SecuriLock® in North America, Safeguard® in the U.K., and PATS in Continental Europe. Passive means that it does not require any activity from the user.
The SecuriLock® System (PATS) is not compatible with aftermarket remote start systems, which allow the vehicle to be started from outside the vehicle. These systems may reduce the vehicle security level, and also may cause no-start issues. If equipped the remote start system must be removed before investigation of PATS-related, no-start issues.
Each encoded ignition key must be programmed into the vehicle's powertrain control (PCM) before it can be used to start the engine. There are special diagnostic repair procedures described in this section that must be carried out if a new encoded ignition key is necessary.
This system contains a new feature named Unlimited Key Mode. This feature allows a customer to program more than eight keys to the vehicle if they request it. Each vehicle in Unlimited Key Mode is set up with a special Unlimited Transponder Security Key. This allows all the customer vehicles to share the same keys, but no other keys from outside can be used to operate the vehicles. For an individual customer, any randomly selected Security Key is acceptable. Refer to Unlimited Key Mode Programming in Key Programming Switch State Control in this section.
The PATS transceiver module communicates with the encoded ignition key. The module is located behind the steering column shroud and contains an antenna connected to a small electronics module. During each vehicle start sequence, the transceiver module reads the encoded ignition key identification code and sends data to the PCM.
The control functions are contained in the PCM. This module carries out all of the PATS functions, such as receiving the identification code from the encoded ignition key and controlling the engine enable. The PCM initiates the key interrogation sequence when the vehicle ignition switch is turned to RUN or START.
All elements of the PATS must be functional before the engine is allowed to start. If any of the components are not working correctly, the vehicle will not start.
The PATS uses a visual theft indicator. The indicator will prove out for three seconds when the ignition switch is turned to RUN or START under normal operation. If there is a PATS concern, this indicator will either flash rapidly or glow steadily when the ignition switch is turned to RUN or START. The PATS system also flashes the theft indicator every two seconds at ignition OFF to act as a visual deterrent.
The PATS will be activated and will disable the vehicle from starting if there is a:
SOURCE: need to know how to install starter on 1997 ford
There "should"only be one large red wire coming from the starter relay on the pass. side fender well going directly to the starter.
It may be black, but i'm sure it's red.
