Drum motor will not come on during any cycle
F25 -
If the control is unable to properly detect motor speed, the washer shuts
down. If a failure occurs during high-speed spin, the door unlocks after
3 minutes
Possible Causes/Procedure
Verify the shipping system including shipping bolts, spacers and the
power cord are removed.
Unplug washer or disconnect power.
Check the drive motor tachometer resistance.It should be
approx. 115
? between motor connections
Check wire harness connections between the drive motor and the
Motor Control Unit (MCU), and between the MCU and the Central
Control Unit (CCU).
Plug in washer or reconnect power.
Check the MCU by looking for operations of the drive motor.
Check the drive motor for powered rotations.
unfortunately if your not familiar with the workings of the motor control and drive motor this is a tough thing to diagnose. its an issue between the motor # 13 and the motor control board # 1 on this diagram.
check the connections on the plugs, disconnect and reconnect them. in most cases it a bad motor control board.
