Blade engages in reverse but not in forward. Changed RIO switch (yellow button) but same problem. What safety switches should I check next?
If you want to solve your problem, click on the link I attach.
John Deere 102 115 125 135 145 155C 190C Lawn Garden Tractor Technical...
SOURCE: Cub Cadet PTO will not engage
Do you have a volt meter or a 12 volt test light?..if you do you can see where you are losing your voltage at..but i would suspect the PTO switch is bad..i hope this has helped.....Keith
With everything you said I never heard you say you checked the oil or put in oil Hope it didn't run tight on you.I'm not sure if your model has one but some also have safety switches under the clutch pedal . If not have you checked the hydrostatic oil im not sure if your is hydro but that could also keep it from shifting in gear and possibly keep it from starting to protect transmission. Just some ideas good luck
