Question about Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
Sony tv kdl52w4100; 13 blinking red lights
Rcving 13 blinking lights, dont belive it is the TCON board because when I disconnect, the same happens
Posted by jeff on
  • jeff
    jeff Aug 09, 2016
    Thank you for the answer, but the laundry list of items it could be are exhausting, how can I eliminate the possible causes 1 by 1?
    Top Expert:
  • Sony Master
  • 76,407 Answers
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Aug 09, 2016
I have a sony bravia kdl46z4100 and is showing 14 blinks in standby mode when turned on. The tv does not turn on. Please help find the part that needs to be replaced. Thanks!
Here is what the service manual says ...14 red flashes- bad TCON or Bad LCD panel, replace tcon board. unplug tcon board if tv stays on without tcon board replace tcon board.
Dec 21, 2017 | Sony Televison & Video
Sony Bravia KDL-xbr4 Replaced TCON board All worked great for a week Had an issue w/ HDMI cable at the box fixed it and now tv comes and the goes off to 6 blinking red lights
6 red flashes- backlight issue, bad main board, or power board or inverter boards- check standby volts on power board. "backlight on" volts should be 3-5v from main logic board then 24v to inverter
Have this from a youtube link find BUT
Better is to look first also on bad leaking or bulged capacitors thats better to replace in the bad components to get a repair because active components died on bad capacitors but after a while because on the build-in protection circuit by faults like deformed or leaking capacitors and even several fuse resistors then after replace a complete board again after a while you will may be get the same kind of problems again, take If you find some or much bad capacitors replacements 10 volts dc higher . begin with control on the power supply first of all.
Sony Bravia TV kdl red blinking led light error codes solutions Sony KDL 40XBR4 KDL 40XBR5 KDL 46XBR4 KDL 46XBR5 Service Manual
Jan 05, 2017 | Sony Televison & Video
Sony Screen wont turn on. Replaces tcon. No Power going to tcon.
Hi Nick, Please trace the 12V line. Most probably it is coming from the main board.
Dec 10, 2016 | Sony Televison & Video
Sony Bravia KDL-60EX500 no longer turns on.
Refer to Sony KDL 55EX500 Troubleshooting Manual Protection Mode Symptom...
5X Blink - TCON & HFR Failure
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board.
First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
see schematics in Sony KDL 55EX500 Troubleshooting Manual Page 23
Sep 15, 2016 | Sony Bravia Kdl-60ex500 60" Inch 120hz...
How do I fix my KDL55HX750? It will not turn on. No sound or picture. Just 3 blinking red lights. What should I do next?!?
http://electro-medical.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience.
Jan 26, 2016 | Televison & Video
I have a 2011 Sony bravia LCD TV model kdl 40ex621....I hit power button and red led turns green then switches right back to red and blinks 4 times, I need to know what board to replace. Thank you!!
Hi Loren,
Timing control ( TCon) board seems to be the culprit in this case. Please check the connectors and the cables to and fro TCon before going for the replacement.
Good luck.
Apr 11, 2015 | Sony Televison & Video
My sony bravia kdl-32s3000 keeps turning off and the standby light is flashing 5 times
Just a copy from Sony:
The 5X blink protection mode indicates a communications error between the TCON/HFR board and the MT5388 microprocessor on the A-Board. First replace the TCON/HFR Board if the 5X protection mode blink pattern occurs. If the TCON/HFR Board does not repair the problem then replace the A-Board.
Oct 24, 2012 | Sony KDL-32S3000 32 in. LCD Television
Power indicater blinks 6 times
"Backlight Error" and the possible location listed is "LCD Panel"
The "LCD Panel" includes the "Inverter MT board" and the "TCON control MT board". The part numbers depend on the serial number of your KDL32BX300. Only one of the inverter boards is available separate from the "LCD Panel". One of the "LCD Panel" assemblies is available for a cost of $518.45. If the serial number of your TV begins with a 5, you are in luck if you would like to replace the "LCD Panel".
Jul 04, 2012 | Sony Televison & Video
Sony 32" LCD TV KDL-32M3000. No picture, LED will
What does it do if you unhook the flat cables going from the tcon to the panel, does the blinking go away and do you have sound then?
Dec 10, 2017 | Sony KDL-32M3000 32 in. LCD Television
The TV won't turn on, and the standby light is blinking in groups of 5. The manual mentions this, but only that the number of blinks is significant, not in which way. What do we do?
Jun 14, 2010 | Sony KDL46EX500 46 in. HD-Ready TV
Sony BRAVIA KDL-52W4100 52 in. LCD HDTV Logo
159 people viewed this question
Top Sony Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
