A
Anonymous Posted on Aug 09, 2016
The sides of a triangle are in the ratio 3 4 5 of the longest side of the triangle measures 40 cm what is the perimeter of the triangle?
terry stevens
Level 3:
  • Master 991 Answers
  • Posted on Aug 09, 2016
terry stevens
Master
Level 3:
Answers
991
Questions
0
Helped
196842
Points
8536
2answers
Regular pentagon QRSTU has a side length of 12 cm and an area of about 248 square cm. Regular pentagon VWXYZ has a perimeter of 140 cm. Find the area of VWXYZ. Round to the nearest tenth.
Find the scaling ratio
Perimeter of first pentagon is 12*5=60 cm
Scale factor (2nd/first)=140/60 =7/3
Ratio of areas varies as the square of the scale factor for the lengths
Area of second / area of first =(7/3)^2 =49/9
Area of second pentagon =248 *(49/9) cm^2
Finish the calculation.
Square 1 has a side length of x, and square 2 has a side length of y. Square 2 is formed by joining the midpoints of the sides of square 1 in order. If x = 2, find the ratio of the perimeter of square 1 to...
Using the Pythagorean Theorem in one of the corner triangles you get
y^2=2*(x/2)^2
Thus, y=(SQRT( 2))*(x/2)
The ratio of the perimeters is equal to the ratio of the sides
P2/P1=y/x=SQRT(2)/2=1/SQRT(2)
The two pentagons are similar. If k is the scale factor for the lengths, the ratio of the areas is k^2.
Pent 1 side =12 cm
Pent 2 side =140/5 =28 cm
Scale factor (larger over smaller) is k=28/12=7/3
Area of Pent_2= (49/9)*Area of Pent_1
Your answer should be C.
1helpful
A rectan Dear Madam Please look at the math questions below. Please help me solve the questions Question 1 : A rectangular tablecloth is 2.5 m long. Trim is to be sewn around the perimeter of the cloth...
1. Well this one is pretty simple. Since you are not supposed to trim the length trim the width instead.
to make the perimeter 0.4 m shorter cut the cloth by 0.2 m width the picture will make it clear.
2. let the length of rectangle be x cm
and breadth = 20 cm
now original perimeter = 2(x+20) cm
new length = x-30 cm
breadth remains same = 20 cm
new perimeter = 2(x-30+20) cm = 2(x-10) cm
According to question
new perimeter = old perimeter /2
2(x-10) = 2(x+20) /2
2x -20 = x + 20
x = 40 cm
hence length of longer side 40 cm.
If you want to directly comm [email protected]
1.the ratio of the corresponding sides of two similar traingle is 3:2 what is the ratio of there height 2.the ratio of the corresponding sides of two similar traingle is 5:9 what is the ratio of...
1. the ratio of there height is 3:2
2. the ratio of areas of the triangle is: 125:6561
3. the perimeter of smaller parallelogram is: 40 cm2
4. THe real length of the object is 7 cm
Open it
If the distance is 2 cm longer than the short side of a right triangle then the lengths could then be assumed as:
160px-triangle_rectangle_vect.svg.png magnify-clip.pngRight triangle A/B = 3 cm
A/C = 1 cm
B/C = 3 cm
k24674
ADMIN Andrew
ADMIN Andrew
