It is a double needle stitch to repair a decorative hem on boys athletic shorts.
It is a double needle stitch to repair a decorative hem on boys athletic shorts. AmanStino Ultra Slim Lightweight Smart shell Stand Cover with Auto Wake...
SOURCE: mine is a simplicity 804 easy lock
Your knives may be blunt and need sharpening or replacement.
Check also if the knives are aligned properly. Remove the material and turn the handwheel slowly. The knives should pass each over like a pair of scissors and there should not be any cap between the blades.
If everything seems to be okay and it still does noet cut tne material, replacement is the only option.
SOURCE: Need replacement cutting blades on my simplicity serger easy lock 804
Allbrand.com or go to Google, type in: "Replacement blades for a serger". Hope this will help. I have the same serger. --Tricie
SOURCE: HELP!
Hi, I have a Simplicity easy lock 804D serger and I have the owner's manual, and I'm able to give you a copy if you don't have one, I need the foot control, and I don't know how to take one.
my e-mail is [email protected], I leave in Florida, in fort myers.
God Bless you.
SOURCE: White Serger 1934D not stitching
No, Sounds like the loopers are not passing properly to pick up the thread, from off the needles.
SOURCE: Need manual for Easy Lock 804 serger
Mine was destroyed in the floods a few weeks ago and I found a download and printable one at simplicityhomecare.com click on the download tab and select manuals and then under sergers chose your model. Good luck with your project.
