Question about Kyocera Office Equipment & Supplies
Kyocera taskalfa 1800 call service c7900 - Kyocera Office Equipment & Supplies
Posted by ragunesan on
Ngoro
    Top Expert:
  • Kyocera Master
  • 2,640 Answers
Kyocera-Mita TASKalfa 1800 Error Code: 7900DescriptionDrum EEPROM error
No response is issued from the device in reading/writing for 5 ms or more and this problem is repeated five times successively.
CausesDR PWB. Main/Engine PWB.
http://printcopy.info/?l=en&mod=erc&brand=Kyocera-Mita&model=TASKalfa 1800&code=7900
Posted on Sep 12, 2016
Shemesh Githigi
    New Friend:
Please someone help on how you can clear code c7900. For kycera 1800
Posted on Jan 10, 2019
5 Related Answers
Anonymous
SOURCE: i also need a service
call service c3100
Posted on Nov 09, 2010
sodeep
Sudeep Chatterjee
  • 3267 Answers
SOURCE: installing a new kyocera TASKalfa 250ci and i got
C3100 Scanner carriage problem
• The home position is not correct when the power is turned on or copying the document placed on the contact glass.
Poor contact of the connector terminals.
Defective scanner home position switch.
Defective engine PCB.
Defective scanner motor.
This copier may need a service adjustment. The problem could be something as simple as a switch not being in home position. Please troubleshoot accordingly. Unplug device when troubleshooting.You should also troubleshoot it by looking to see if anything is blocking or stuck causing the carriage to not go into position.
Posted on Dec 22, 2010
shawn38
Shawn
  • 200 Answers
SOURCE: my kyocera taskalfa 180 showing
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Posted on Mar 02, 2011
hirun_ph
SOURCE: reset all originals in DP
reseat orignals on DP.
Posted on Sep 05, 2011
ASHIQ
SOURCE: Free service manual with code
To reset -
C-TECH INFOWAYS
Posted on Nov 19, 2011
Kyocera taskalfa 1800 call service c3100
Place a telephone call to your local Kyocera service representative and specify code c3100.
Jun 21, 2018 | Kyocera Office Equipment & Supplies
Kyocera Taskalfa 1800 monochrome Multi Function Laser Printer how solved call service c7900
empty the waste toner from the drum unit small removable covers on both sides
Mar 20, 2018 | Kyocera Office Equipment & Supplies
Keyocera taskalf 1800 photo state black& whit printer how solved call sevice c7900
Place a telephone call to your Kyocera equipment servicer and mention code c7900.
Help i dont know how to fix my problem with me kyocera taskalfa 1800... call service c2000
Your drive motor could be faulty, or the drive section under strain, meaning the drum unit could be locked.
Nov 08, 2017 | Kyocera Office Equipment & Supplies
Whats the cause of call service C7900 for KYOCERA TASKALFA GX 2200?
Drum EEPROM error Reading from or writing to EEPROM cannot be performed.
Causes
Poor contact in the connector terminals. Defective drum unit.
CHANGE THE DRUM HOUSING
Jul 14, 2017 | Kyocera Office Equipment & Supplies
KYOCERA TASKALFA GX 2200 is displaying call service C7900, how can i fix?
Drum or Dv can cause it if they are not seated correctly. or the board that the drum or dv is connect too. might be bad cable or is not connected.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Master reset code Taskalfa 180
Kyocera mita task alfa 1800..error code 0800
Jan 18, 2012 | Kyocera TASKalfa 180 Copier
2,139 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
