Question about Electric Garden
I have an old champion electric lawn mower that is VERY noisy can I oil it & where?
Electric champion lawn mower very old
Posted by Kay taylor on
Salvagedrover
    Sergeant:
  • 417 Answers
It's probably a bad bearing, you can try to remove it, then look on the bearing race for numbers and letters, and try to track that particular bearing down on the Internet. It may be too much work or money to fix though, most things are pretty much disposable these days.
Posted on Sep 03, 2016
5 Related Answers
Anonymous
  • 22 Answers
SOURCE: I have Black and decker electric lawn mower does not start
one of the problems i found with electric detectors was that they do not tell you if there is a break in the neutral cable so you could have a break there,another problem is that the levers can break inside the cover giving the impression that it should work but is not making contact with the switch ,hope this helps
Posted on Mar 30, 2009
Anonymous
  • 34 Answers
SOURCE: My electric lawn mower starts briefly and then trips the circuit
check cord from plug to the electric motor.if it has a reset or breaker check for damage. if no obvious damage problem is electric motor.may be cheaper to buy new 1
Posted on May 06, 2009
Anonymous
  • 18 Answers
SOURCE: Black and Decker 18 inch electric lawn mower turned off
Try the link at the bottom of this page : "Find Manuals".
Posted on Jun 11, 2009
Anonymous
  • 12 Answers
SOURCE: Electric Start Spns & won't engage
i have a riding mower and i get that problem sometimes and what i do to fix it is i take a metal pole and put against the motor and gear on the starter and push when it moves i turn the key and that normally fixes it.
Posted on Jun 15, 2009
MNfisherman
Nate Stansfield
  • 11896 Answers
SOURCE: I have an old Black and Decker 18 electric mower
Here is the black and decker website:
http://www.blackanddecker.com/ProductGuide/CategoryOverview.aspx?cPath=1498.1670
Most the old models where 6 amps. 1/2 hp
You can get another one from ebay or craigslist
Posted on Sep 04, 2009
My corded 18" corded electric motor does not run although outlet and cord ok - mower is 2 years old and used once a month
There should be what is called a "thermal breaker" on this. It should either re-set itself or you may have to push a little button down by the motor.
Please let me know, we repair this kind of equipment.
Feb 10, 2010 | Black & Decker Lawn Hog 18-Inch 12 Amp...
I have an old Black and Decker 18 electric mower that has reached it end of life. I don't have a model number, it has two 9 or 10 inch blades with belts back to the motor. It is an old orange version. I...
Sep 04, 2009 | Black & Decker 18", 6.5a Electric Mower
Mower Blades
most lawnmower shops can help you prob just a worn keyway ! or goto black&decker.com for closest repair shop?
Aug 27, 2009 | Electric Lawn Mower
My Wolf electric lawn mower will start but cuts out after 30 seconds then after some minutes will start aagin. Have checked power is getting to motor and is fine. Also put multimeter across motor &...
There may be a fault contact due to vibration check all the electrical wires and contacts if they are very well connected check corrosion point at contacts, use wd40 spray oil in the motor and contacts, there may be a fault in the carbon contacts to the rotor.
Hope it help
Jun 25, 2009 | Electric Lawn Mower
Electric mower won't cut well
change a new blade. when was the last time the blade gotten changed?
May 22, 2009 | Black & Decker Lawn Hog 18-Inch 12 Amp...
Electric lawn mower slowed down then stopped working?
The carbon brushes on your mower have worn and, need to be replaced; order them from black & decker
May 21, 2009 | Black & Decker 19" Electric Lawnhog...
Garden Logo
83 people viewed this question
Top Electric Garden Experts
dannydoesita
Mike
ray gallant
Are you an Electric Garden Expert? Answer questions, earn points and help others
