Question about Turbo Air Refrigerators
M3 turbo air freezer. M3F24-1 temp on display is not temp of box
Posted by Todd Evans on
Dennis Boxerman
  • Turbo Air Master
  • 1,305 Answers
This could be a bad temp sensor or lack of proper air flow. Make sure the evap fan runs when it's supposed to be running. Also make sure the evap is not freezing up. all these items can cause what you are describing.
Posted on Jul 28, 2017
Turbo air m#TSF-72SD will not hold below freezing. Cleaned coil an temp dropped to 29 but no further...
If everything else is in proper working order, either a refrigerant level issue or and expansion device issue. If system constantly runs the previous, if not, possible temperature control. Look for system cycling or not cycling.
Jan 10, 2018 | Turbo Air Freezers
Why it make loud sound like fan is thatching some metal when i plug in?
check the fan blade to make sure it is tight on shaft. also check to see if any of the fins are bent could be that they are hitting the housing of the fan motor.
Jun 07, 2014 | Turbo Air MUF-48 M3 Series 2 Door 48"...
I have a turbo air upright freezer. having trouble understand ertain sensors and how this unit functions. on the schematic there is a f sensor and d sensor and bi metal switch. Customer called that this...
without a model number, I can only tell you the general function of most freezers. Theory is that the bi-metal is probably a defrost heater safety to prevent overheating. A sensor of some type will prevent the evaporator fan from coming on until the evaporator temp hits a preset temperature. Some freezers are setup to terminate on either time or temperature, whichever occurs first.
Hope this helps some. Need model number for further help.
Apr 13, 2017 | Turbo Air Freezers
I need a control panel for my turbo air freezer. Where could i but one? The problem with my freezer is that the panel will not turn off the compressor.
http://www.turboairinc.com/TB-Sale%20Network/TB-Sales.html
go to this web site and it will show you where the places you can purchase parts.
Are you sure it's the control and not just a temp probe not reading correctly. If it reads a false number, the unit will either never shut off or never come on as the controller is controling based on incorrect information. You may want to look into that first. Control panels are not cheap.
Oct 10, 2010 | Turbo Air Freezers
Msf-49nm freezer will not go below 34 degrees farenhight
Change the temp control,check to see if it is iced up on the evaporator
Sep 15, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Frigidaire freezer LFFH21F7HWG. the temp gauge outside registers only 0. I have 3 thermometers inside all register 18 degrees. ice cream is soft in the box. machine was delivered last Tuesday. the freezer...
these freezer are designed to run about 70 percent of the time the temp displayed can vary by +/- 3 degrees..make sure you have fan operation in the freezer and the air flow is not blocked or restricted. also make sure that the door is sealing properly
Aug 31, 2010 | Frigidaire 20.6 cu. ft. / 583 liter...
My Freezer does not maintain the right temp. It wont maintain my food frozen.
The thermostat is faulty.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Aug 17, 2010 | Turbo Air 23 cu. ft. / 651 liter...
Temp. can not reach 0 degree.
things that need checking:
refrigerant level. Super heat. Condenser clean? Compressor effeciency.
These are things that an experienced tech can check. If you have some experience and gages/ tools, I can give you some things to do but most of this requires experience.
Let me know if I can be of any further help.
May 30, 2010 | Turbo Air 49 cu. ft. / 1388 liter...
Refrigerators Logo
159 people viewed this question
Top Turbo Air Refrigerators Experts
Dennis Boxerman
Lawrence Oravetz
john h
Are you a Turbo Air Refrigerator Expert? Answer questions, earn points and help others
