Question about Lexmark X Office Equipment & Supplies
What other possible sftware version is compatable for lexmark x1205 printer please help seems to be outdated but cartridges are still available
Software for lexmark x1205 printer/copier
Bill Boyd
    Top Expert:
  • Lexmark Master
  • 53,816 Answers
Go to printer properties in the control panel and click on latest driver
Posted on Aug 06, 2016
Has Lexmark stopped manufacturing ink cartridges such as "Lexmark 16", "Lexmark 26", "Lexmark 17", "Lexmark 27", which are required for Compaq IJ650 printer? Is there an alternative from any other
Hi
I have checked 5 sites selling ink cartridges - original and compatible - including Amazon and Ebuyer, and they all appear to have the products you need. I give below the sites concerned:
Search results for lexmark 16
or
Lexmark 16 26 Black Colour 2 Printer Ink Cartridges for Compaq IJ650 IJ652...
or
Compaq IJ650 Ink Cartridges
I can not find any alternatives except the compatibles listed on these sites.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Lexmark Office Equipment & Supplies
Tip
Lexmark 2500 series ink cartridge problems
ok, i called lexmark and finally figured out the problem so many people are having with the unsupported cartridge error. it seems there are a few different varieties of 2500 series printers. mine for example is a 2500, came with a 2500 series user manual, but is actually considered a 2580! this is huge for the ink cartridge- as a 2580 is the only version that takes number 2 and number 3 cartridges. i switched from the 28 and 29 cartridges that the manual said to use and the box said was compatible for and put the 2 and 3 cartridges in, and it worked fine. i complained to lexmark that the manual is deciving and costing people money. she offered to send me the right cartridges free of charge. i hope this helps some of you!<br />
on Jan 04, 2011 | Lexmark X2500 All-In-One Printer
My Lexmark Impact S305 will not print in color.
If you're using a remanufactured/refilled cartridge, the printer will not be able to recognize those cartridges after the firmware update. The firmware update restricts use of refilled/remanufactured cartridges. That's to prevent damaging the printhead.
If you're using genuine Lexmark cartridges, please contact our technical support for assistance.
Oct 02, 2012 | Lexmark Prevail Pro705 Wireless All-In-One...
Bought compatible cartridges for lexmark S405 all in one. Won't authenticate them. locked out of printing. Any ideas
For the most optimal output experience with your AIO, Lexmark recommends that customers update their firmware. The firmware helps ensure that customers receive the highest yields of ink available from the cartridges, which offers the greatest value and means fewer necessary cartridge replacements.
If you choose to upgrade firmware, note that unauthorized use of third-party 'cloned' cartridges will no longer be possible.
When purchasing ink cartridges, Lexmark customers have two options:
Regular ink cartridges without license terms (100A/100XLA) that you may a) return to Lexmark free of charge (for recycling by Lexmark), b) refill, recycle or remanufacture themselves, or c) provide to third parties for refilling, recycling, or remanufacturing. Any Regular ink cartridge can be refilled by a customer or a third party and will continue to work in their Lexmark printer.
Return Program ink cartridges that provide customers with an up-front discount in exchange for their agreement to use the ink cartridge once and return it only to Lexmark for remanufacturing and recycling.
Aug 31, 2011 | Lexmark Interpret S405 Wireless All-in-One...
Replaced black ink cartridge (not lexmark brand) printer will not recognise it even though supposed to be compatible?
Regular ink cartridges without license terms that they may a) return to Lexmark free of charge (for recycling by Lexmark), b) refill, recycle or remanufacture themselves, or c) provide to third parties for refilling, recycling, or remanufacturing. Any Regular ink cartridge can be refilled by a customer or a third party and will continue to work in their Lexmark printer.
Jul 11, 2011 | Lexmark Interpret S405 Wireless All-in-One...
How to replace the ink cartridge
1. Look at the indicator light on your Lexmark printer. You'll need to replace ink cartridges when the light flashes or turns red instead of the standard green.
2. Purchase Lexmark ink cartridges. You can buy the brand name or purchase a generic version that is compatible with your printer. You can shop for low cost ink cartridges from ABC Ink.
3. Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
4. Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
5. Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
do rate the solution if it helps
Nov 26, 2010 | Lexmark X1240 All-In-One InkJet Printer
Can i use print cartridge 70 or 12A1970 for printer lexmark P3150
#70 cartridge is not compatible with the Lexmark P3150 printer. Compatible cartridges for your printer available in the Lexmark website at http://bit.ly/9DTsPt. Thanks.
Oct 13, 2010 | Lexmark P3150 All-In-One InkJet Printer
Lost my manual, need to change the ink cartridge, help
  3. Step 3 Remove the old cartridges from your printer. Grip the sides of the Lexmark ink cartridges and pull it out. Dispose of the ink cartridges in a recycle program like the one at Staples or save the cartridges for refill.
  4. Step 4 Install the new ink cartridges after removing the protective tabs. Avoid touching the IC chip when installing the new Lexmark ink cartridges. Replace the cover of the printer.
  5. Step 5 Allow the Lexmark printer to run a nozzle test. Print several pages with the new ink cartridges to make sure you installed the ink cartridges correctly. The indicator light should return to a solid green color.
Apr 24, 2010 | Lexmark C533DN InkJet Printer
Need refillable ink cartridges for lexmark 3650 all in one printer
Refillable cartridges for your printer are 36A and 37A. You also have the high yield version: 36XLA and 37XLA.
The important thing is that after the number there is the letter A.
Here is link to Lexmark's site, with the cartridge compatibility list for your printer:
http://lexmark-cartridges.com/cfv2/printer.php?lang=uk&partner=&productName=Lexmark+X3650
If you find my answer useful, please vote. Thank you!
May 07, 2009 | Lexmark All-in-One Printer with PictBridge
X11oo seies driver out dated
Did you already search the lexmark website for possible driver updates?
Jun 24, 2008 | Lexmark X2500 All-In-One Printer
Open Questions:
Top Lexmark Office Equipment & Supplies Experts
Muntejaya Ginting
Muntejaya Ginting
CheckitRight
CheckitRight
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
