Cars & Trucks Logo
D
David Harrison Posted on Aug 06, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
BF wagon eye level brake light is not working have tested globe and globe is working. Also reverse lights not working
Does the eye level brake light have a separate fuse The reverse lights not working have changed fuse What the possible cause for this fault
Randy Ohler
Level 3:
  • Cars & Trucks Master 14,585 Answers
  • Posted on Aug 06, 2016
Randy Ohler
Level 3:
Answers
14585
Questions
8
Helped
3939618
Points
39683
If the other brake lights work, probably broken wire. Eye level meaning Suv hatch? If so, the wires tend to break at the rubber boot from the hatch to the body. The reverse lights run threw the neutral safety switch on the transmission. Could be a broken wire, most times it is the switch.
1helpful
What color is the reversing light positive on a 2005 Citreon xsara Picasso.
look at reverse globe socket the wire that goes to the centre of the globe is most likely positve and the other wire on the side of the globe is car body. Or get a 12v dc probe from an auto shop and test the wires at reverse light globe connector.
Blowing brake fuse as soon as it touches, the only thing that stops it blowing is pulling a plug from the bcm, not sure if im just pulling power to the bcm or whether theres a bcm fault???
Hi Steve Is this a new fault has it just started to occur for no reason. You need to start with the basics i.e. have you recently replaced any globes? not necessary brake light globes ,If you have re check it make sure its the correct one,(check it against the other side). make sure it's not fitted incorrectly upside down. remove it and try brake lights again. Move onto your brake lights remove eye level globe and brake light globes left and right now try brake lights does it still blow fuse if not check all globes, connections and local brake light wiring for any shafing. Fit each globe one by one if it blows again remove that globe and try the others, Do you have tow bar and electrics fitted Check and make sure wiring in or around the socket has not come adrift and shorting out the brake light circuit. If all the above fails get it inspected by a Dealer or auto electrician, as the fault may be a lot more involved. Preferably a dealer as they will have the correct information on your vehicle. Good luck
1helpful
2answers
How do I fix my left reverse on my by commodore
Is it the globe or no power to the socket?.... Either way above your number plate you'll see the lense and it'll have a clip or screws either unclip and remove or unscrew and remove there you'll find the globes
Vt holden commodore brake lights dont work
There could be a couple of reason why your brake lights are not working these are all common faults.
1.first remove the brake lens and check globes.
2.Next check the globe socket as they tend to get hot and the plastic housing brakes away so the globes don't connect.
3.get a test light and check for power.
4.if everything is ok then I would be replacing the brake light switch under the dash that makes contact with brake pedal.
good luck
Why wont the brake lights shine when pressing the brake pedal but the tail lights are working on the same bulb
test the brake light switch located at the brake pedal, disconect the switch & bridge the wires, turn ignition on if you have lights its a faulty switch (very common on ford falcons) if not check you have power at that plug, if power check the globes cause you could have blown globes as they are twin filiment globes (1 globe but 2 lights tail & brake) & the brake filiments might be blown.
2helpful
02 Focus Wagon - Rear tail light/brake light keeps blowing bulbs. Bulb is white when removed, replacement bulb last about a week, then blows again. Any idea what the problem may be.
If a bulb blows white the gas mix in the globe is incorrect and you probably got hold of a bad batch of globes from your supplier. Try buying your bulbs from another source and see if that works out better.
2answers
Subaru legacy 96 running tail lights out
The globes on tail lights are usually 2 elements so just because ur brake when pressed works doesnt mean the second part of the globe is working id buy new tail light globes or at least see if both little wires are going from one point to the other it looks like 2 little power lines .if top and bottom are both going to the other side tgen its another prob but if top or bottom line are broke then thats the problem hope i didnt confuse u but im sure u will get what i mean when u have alook at the globe
2helpful
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
