SOURCE: I have a Pioneer DV
Hi edwardm1,
If you are only hearing part of the audio from your DVD player, I would suggest you check your audio settings before seeking repairs.
Audio can be encoded to a DVD in several ways. If the audio on the disc is different than the settings on your DVD player, you may not hear all of the audio layers. For example, if your DVD is encoded in 5.1 Surround Sound, but your DVD player is set only to play basic Stereo, you may only hear portions of the audio.
Try accessing the menu on your DVD player, and look for the audio settings. If there is a higher setting available than is currently selected, try a higher audio setting. A higher setting should also be compatible with lower types of audio encoding.
If this does not improve your audio, or if you need help navigating your product menus, I would recommend giving Pioneer's toll-free support line a call at (800) 421-1404.
Thank you,
Jason,
Go Ahead. Use Us.
SOURCE: i cant hear sound from a dvd player,
This is gong to sound lame because I don't know the answer but I can point you in the right direction. The same thing happened when I got my new TV, but that was years ago. If you have you TV set to broadcast in surround sound, it sends the talking to a "fifth" speaker in the middle of the room. The background sounds, like thunder and gunshots, are sent to the speakers that project out into the room, so it sounds like the background sound is all around you. HOWEVER if you do not have a surround-sound speaker system, there is no fifth speaker for the voices to go to. Now, i don't remember what the settings are called, but I'll bet if you call the store where you got your tv they can tell you.
SOURCE: Can't hear the voices when I play a DVD, only the music
WE'VE HAD THE SAME PROBLEM SINCE WE MOVED AND DISCONNNED THE SPEAKERS?
IS IT POSSIBLE THAT THE SURROUND SOUND WAS NOT HOOKED UP? AND THIS COU\LD CAUSE THE PROBLEM?
SOURCE: Problem with voice sound on DVD player FX900 Sony.
you have probaly changed audio tracks on the dvd,just go to menu and audio,and pick another audio track,a lot of DVDs come with more than 1 audio track (im talking the actual DVD not the player
SOURCE: i can't hear the voices when i play dvds
Change your audio setup to stereo. if you are running two speakers
