Washing Machines Logo
Question about Electrolux Washing Machines
Electrolux ewf1470 front loader trips power while filling
Posted by Jeffrey Long on
5 Related Answers
mnwarfield10
mark warfield
  • 453 Answers
SOURCE: Electrolux front loader wouldn't stop filling.
change water valve sounds like its stuck open ... if not only other thing it could be is your main pcb control board ££££££
Posted on Dec 30, 2009
Anonymous
  • 1998 Answers
SOURCE: Hi - My Electrolux XL
if you have no power going to the control panel then it would be your plug that your having the problem with cord of the machine this is a very common thing to happen inb machines simply find where the plug goes into the back by removeing the top panel and assure that you have power coming in to the unit if you have any further questions message me back and pleae remember to rank how this opinion has helped it allows me to continue to help others with similar situations Thanks again Rick
Posted on Jan 26, 2011
charleshucke
Charles Huckeba
  • 1114 Answers
SOURCE: my electrolux 7kg ecovalve front loader will not
The control panel may need to be replaced, this is a fairly common occurrence.
Posted on Mar 11, 2011
Anonymous
  • 6277 Answers
SOURCE: Hi, My electrolux front loader ewf1087 will fill
(please read all)
You have not mentioned the filter so I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Jun 06, 2011
richroth
Richard Roth
  • 9472 Answers
SOURCE: Electrolux EWF 1090 front-loader - the pump cover jammed - help!
You will need to replace the pump assembly. Here is the pump to order. There is no fix for the leak.
The part comes with a 365 day, any part, any reason return policy.
Posted on Nov 09, 2012
1helpful
How do i change fuse in my electrolux ewf 1087 front loader
There is no fuse in the machine. If you have no power to machine check the house fuse, it may have tripped.
Our electrolux front loader Washing Machine EWF 1083 won't fill with water and there is a humming sound, does anyone know what the problem is ? cheers
Just a long shot - it may be the water inlet filter is blocked? normally there is a little mesh filter in the hose that screws onto the back - check that its not full of crap. This happened to me only a few weeks ago hope its as simple as that for you.
My front loader does not get no water in it
Hello - Washer not filling with water can be caused by many reasons. Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Are the house valves turn on fully? Contact a professional to move forward accurately?
1helpful
3answers
My new electrolux front loader is not filling with water during the wash cycle. The clothes are soaked, but there is NO extra water in the bottom of the tub. It does have extra water in there during the...
front loader washers fill accourding to how big the load size is on all front load washers.There should be no water above the center with a full load.If it is spinnig out and draining then it is working properly:)
Open Questions:
Top Electrolux Washing Machines Experts
nu267
tina gallow
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
