Renault BP4495T3471477 code is 1912
www.ukbookshelf.co.uk
Mention FixYa Forum
You can get Renault radio codes from this link: Car radio codes in Uxbridge London Gumtree
SOURCE: Reset radio code for Acura RL 1996
You need to get the serial number off the sticker attached to the radio. It will require pulling apart your dash. You start at the air vents directly on top of the radio. These tend to be fragile so be carefull when pulling them. You use something skinny like a credit card to wedge between the vents and the trim to release them. Both vents will come directly out in one piece. From there twist off your shift knob. Remove the ashtray. Then pry up the wood trim of the center console. You will then have access to 4 or so screws that hold the radio and climate controls in place. The entire thing comes out as one piece as well. You should see your serial at that point.
SOURCE: how to entry new code into renault laguna car
have you got the code? it will be printed on a sticker in your service books, normally inside the front page. enter the first number by pressing 1 on the radio until you get to the number you want. repeat the process using the number 2 button for the second and so on. once you've entered the four digits hold the number 6 button for about 3 seconds. the radio should beep and then you should have music.
SOURCE: coding a key for a renault laguna
Renault Laguna II Key Remote Control Programming
LAGUNA II INFRA RED RESYNCHRONISING
1. Turn the Ignition OFF.
2. Press the central door locking button for more than 5 seconds. Note: the door should lock then unlock.
3. When this happens 15 seconds is allowed and the immobiliser warning light illuminates.
4. Point the 1st key at the receiver and press the button once, the doors should lock and unlock.
5. Point the 2nd key at the receiver and press the button once, the doors should lock and unlock.
6. Check the remote control unlocks and locks the doors.
SOURCE: Renault Laguna radio code number
try instant radio codes dot co dot uk unfortunately this will cost about 15 quid hope this helps
SOURCE: radio code 2002 renault laguna
You will need to contact your nearest dealers, they (For a small charge) will reset it for you.
