Question about Canon Office Equipment & Supplies
Error code - E225-0002 - Cannon i-sensys fax-l150 Does anyone know a fix to this?
Have turned off and on by hard reset by removing power cable and plugging back in. Unplugged and plugged back in telephone cable. Error still appears when unplugging the telephone cable. The machine is a number of years old. Any other ideas?
Lenin Hudiel
    Master:
  • Canon Master
  • 913 Answers
Hi. That error indicates there is a problem in the scanning unit. Get technical support
Posted on Feb 20, 2018
5 Related Answers
Anonymous
  • 121 Answers
SOURCE: HPcolor laserjet 2840 clicking with message "scanner bulb warming
Removal instructions:
1) unplug everything and move the unit to where you can work on it.
2) Remove the paper, and remove the hinged lid (tilt the lid to the up position and lift directly up and off).
3) Remove the push button cover which lifts directly off - straight up.
4) At the top of the button control module is a recessed release clip. Use a flat blade screwdriver and push down on the clip. While pushing down, slide the control button assembly down. lift the outside edge up (there are straight clips on the inside edge). Lift up slowly as the connection cable needs to be unplugged. the cable itself unplugs. Just pull down evenly grasping the top blue laminated section. The blue goes to the outside (contacts go to contacts on the inside). Set the button control unit aside.
5) Using a #10 Torx screwdriver, loosen the two screws in the back corners of the glass cover assembly. Lift the glass assembly up (like changing an ink cartridge), and pull the front lip left and right forward - there are two clips at these locations. Pull forward and lift up. Remove the glass cover assembly off and set aside. Note, tip over and remove the scews (best to remove and put back in after the cover is back fully in place). In reassembly, be sure to feed the control button cable back through the hole, and that it goes back into place the way it came out (including folding back into the slot under the button control assmebly).
6) The black plastic cover has two metal clips visible. These are not the release clips (they hold a glass piece in place under the black plastic cover). The release clips are outboard of these metal clips and are two slots. Insert a small flat blade screw driver, and push the handle toward the center. While prying, lift the cover at that end up, pry the other end and lift the black plastic cover off.
7)While you're in there, you might as well clean the mirrors (THERE ARE FIVE OF THEM)and glass. At the front of the lamp on the botton, the lamp wires lead to a white two piece plastic connector. Unplug the lamp wires. Where the lamp is, toward the front is a black philips screw in the clear plastic piece that holds the front end of the lamp. Remove this screw, and lift the clear plastic piece with the front end of the lamp up slightly, and then pull the full lamp assembly forward and out. This will open the space to the mirrors and glass. Use a Q-Tip and small pieces of paper towell and glass cleaner to clean the mirrors and glass strips. I tried to remove these to clean them, but the metal clips were too tight.. better to clean it all in place. BE SURE TO CLEAN THE EYE!!!!!
8) Clean the bottom of the glass top assembly.
9) Reverse the above to reassemble. Be sure to plug the lamp back in, and the button control assembly. Leave the black plastic cover off.
10) Place the glass top assembly back in place, and snap it down before dropping the screws in the back holes.
Don't know why, but you should be good to go.
After doing the above if in a few weeks you get the same msg again go back in there and take the black top off the housing that the mirrors are in and leave it off!!!! sound crazy but it has been working on a lot of the machines that come in here.
Posted on Jul 13, 2009
Anonymous
SOURCE: HP 5510 all in one
my 5510 sez printer cartridge error what do i do to fix that
Posted on Nov 03, 2009
komguy
Craig Gillette
  • 2306 Answers
SOURCE: Got
It's a bad printhead, when it is removed, power should come back, but you need a new printhead. Wrong cartridge means the printhead is bad.
QY6-0049-000
Posted on Nov 23, 2009
Testimonial: "Helped me make the decision to just buy a new printer. Thanks"
Everett Lin
  • 990 Answers
SOURCE: On our Ep3170 we get a C5 error code and the wrench symbol
Hello sir;You must remove the left side panel to access the service switch(s1) on PWB A you press this switch to chose the "C" then enter 0 press "#" ,then press "CLEAR" to terminated.
Posted on Jan 18, 2010
pineworks
Clive
  • 4345 Answers
SOURCE: printer shows error code Oxc18a0101
Hi there
This is only some thing you can try it may work.
Solution 1:
1. Press and hold "left arrow" key
2. Press the "setup" key and release both keys
3. Press and release the "OK" button
4. Press and release the right arrow button until the display says “System Configuration Menu”. 2. Press and release the “OK” button.
5. Display should say “Hardware failure status”. If not there already, Arrow Key over to “Hardware failure status”,
6. Press and release the “OK” button.
7. Display should say “Hardware failure status: Clear. Press OK to clear”.
8. Press and release the “OK” Button. Message changes to “Hardware failure status Cleared. Press Cancel to continue”.
9. Press and release the “CANCEL” button as many times as necessary, so that, either the “Welcome to Photosmart Express” screen appears, or, the “Ink System Failure” screen appears. PLEASE DO NOT TRY TO PRINT AT THIS STAGE.
10. Using the Power Button, turn the unit OFF and unplug the power cable from back of the printer and wall outlet.
11. Wait 30 seconds for the power to get discharged and then plug the power cable into the wall outlet first and then into the back of the printer
12. Turn the unit on. The printer may display message “USE POWER BUTTON TO SHUTDOWN THE PRINTER” followed by “PRESS OK TO CONTINUE”. Press OK.
13. If the printer has already initialized, then go to the next step. If not, the printer will start the “ONE TIME INK INITIALIZATION PROCESS”. Allow this process to complete and do not interrupt. Once the initialization process is complete, the printer will print out a Diagnostic Page.
14. To verify printer functionality print a SELF TEST PAGE. If SELF TEST prints, then printer is ready for use or Software Installation.
15. If the error is still there, or reoccurs the printer is already defective.
Solution 2:
1. Press the On button to turn the printer off.
2. Unplug the power cord from the back of the printer.
3. Remove all the ink cartridges.
4. Wait two minutes.
5. Plug the power cord into the back of the printer.
6. Press the On button to turn the printer on.
7. Install the ink cartridges when prompted.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 16, 2010
0xc18a0001 error message, please provide solution
The printer's control panel displays alphanumeric code error without any additional information on the cause of the error. Carryout the steps below to resolve the issue.
Reset the printer
1. Power up the printer and wait until it is idle and silent.
2. Do not disturb the wireless connection if the printer is connected to a network.
3. If the printer is connected to your computer using a USB cable, unplug the cable from the printer's rear.
4. Remove the ink cartridges from the printer.
5. Plug the power cord out from the printer while the keeping the printer turned on.
6. After a minute, plug the power cord back to the wall outlet and into the printer's rear.
7. If the printer fails to power on automatically, press the power button to turn it on.
8. Reinstall the ink cartridges.
9. Print a calibration page if prompted.
10. Plug-in the USB cable back to the printer if you unplugged it.
11. Try to print.
Service your printer
  1. resetting the printer did not resolve the issue and the error is displayed again, contact the printer's manufacturer and get your printer serviced. Do not forget to claim a free service if the printer is still under the warranty period. Call our Toll-free to get HP Printer Support 1-866-293-9220
    http://ww123hp.com/
Oct 08, 2014 | HP Photosmart C5180 All-In-One InkJet...
Canner Error 52 Hewlett Packard M1522nf
Please try the below listed steps that should resolve the issue.
  1. While the printer is ON, unplug the power cord from back of the printer.
  2. Also unplug any other cables connected to it. ( USB / Telephone, LAN cable etc )
  3. Wait for 3 minutes.
  4. Plug in the Printer Power Cord directly to wall outlet and then to the printer.
  5. Printer should power ON automatically, else press the ON button to do so.
  6. Now try making a Copy. It should work.
  7. After which connect all the cables / cords that were unplugged.
Jun 24, 2014 | HEWLETT-PACKARD Hewlett Packard 53A...
Computer does not recognise speedstream 6300
you try form USB or LAN interface \\Ethernet connection (recommended)
  1. Plug one end of the RJ-11 telephone cable into an unfiltered telephone wall jack (enabled for Sympatico High Speed Internet service).
  2. Plug the other end of the RJ-11 telephone cable into the DSL port on the back of the modem.
  3. Plug one end of the RJ-45 Ethernet cable into your computer's Ethernet port.
  4. Plug the other end of the RJ-45 Ethernet cable into the Ethernet Port 1 on the back of the modem.
  5. Insert the rounded end of the power adapter into the Power port and the dual-pronged plug end into your power outlet.
  6. Press the power button to turn on the modem.
USB connection
  3. Plug the small, square end of the USB cable into your computer's USB port.
  4. Plug the wide, flat end of the USB cable into the USB port on the back of the modem.
May 28, 2012 | Efficient Networks Speedstream 6300...
I have a Coby15 inch LCD TV hooked up to a digital cable box, only of few of my channels will come in. I can try and tune to the channels and they say please wait, this channel will be available shortly,...
Try turning off the power on your cable box, then unplug it from the outlet or surge protector. Wait 30 seconds and then plug the cable box back in and turn it on. When cable or satellite boxes are unplugged from a power source they reset themselves when turned back on, this can solve many problems. If you are still unable to receive your channels than this is a problem on the cable service provider's end. Call them immediately and describe the issue, they will be able to reset your box over the telephone and/or replace your cable box.
Feb 15, 2011 | Televison & Video
I have a SKPE Phillips phone VO1P8411B/37. In an effort to fix the phone I de-registered it. When I select REGISTER, it comes back with 'Registration failed'. I tried to put in the default code of 0000...
Firstly, unplug the base unit, then remove from this base unit the ethernet cable and most importantly, unplug the telephone line! Then remove the batteries from the 2nd handset. Keep everything unplugged for a few minutes, then plug the power into the base unit, wait 1 minute, then plug in the Ethernet cable and wait 5 more minutes. Do NOT plug in the telephone line just yet. After the 5 minute wait, put the batteries back into the 2nd handset and then follow the registration instructions from the manual (copied below)...
Make sure you have configured the language, country code, and area code of your
phone before registering additional handsets.
1. Press "Reg.". Register shall be highlighted.
2. Enter the system PIN (Default: 0000). Use "Clear" to correct typing errors.
3. Press "Enter" to confirm.
• Your handset starts searching for the base.
4. Press the top button on the base unit until the two indications turn off.
• If registration is unsuccessful, the signal icon displays steadily.
TIP: IF REGISTRATION FAILED, REPEAT THE ABOVE PROCEDURE.
Like other methods, you must hold down the button on the base unit until the lights STOP blinking. When you have successfully registered your 2nd handset, then plug in the telephone line into the base station. I did the above and it worked! The trick is to be patient and wait the few minutes while everything resets itself.
Aug 05, 2010 | Philips Lands Phones
Printer turned off when paper jammed and does not turn back on. Photosmart C4280. I have unplugged it and plugged it back in. Is there a fuse or reset button?
Please follow the below steps.
STEP 1.
1. Un plug the power chord from the back of the printer.
2. Press and hold the power button of the printer.Wait for 30 seconds.
3. While holding the power button, re-plug the power cable.
4. Turn on the printer, if it is not on.
STEP 2.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Then, if we still get the same error, "paper jam", please open the below link and follow the steps.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00702180&cc=us&lc=en&dlc=en&product=1153481
Apr 27, 2010 | HP Photosmart C5180 All-In-One InkJet...
I unplugged from the wall. Now I have an error
Hai,
The Ink delivery system is malfunctioned, please perform below troubleshooting to fix the issue.
Power Drain:
1.Press the On button to turn the printer off.
2.Unplug the power cord from the back of the printer.
3.Remove all the ink cartridges.
4.Wait two minutes.
5.Plug the power cord into the back of the printer.
6.Press the On button to turn the printer on.
7.Install the ink cartridges when prompted.
If you still get the same error message (0x code on display) reset the printer.
Reset the Printer:
1.Remove the ink cartridges from the printer, close the cartridge doors.
2.Wait for 30 seconds and disconnect the power cable from the back of printer, while the printer is ON.
3.Press and Hold "OK" and "Cancel" key, while holding them, insert the power cable behind and keep holding them for 10 seconds and then release.
4.If the printer goes OFF, push ON button to turn it on.
5.Then insert the cartridges when the display prompts and check the printer.
If the 0xc18 or 0xc19 ink system error code displays on the front panel, service the printer.
Thanks & regards
Rizwan.
Jan 31, 2010 | HP Photosmart 3210 Printer
The caller id on my vtech cordless phone stopped coming in clearly, why?
Try unplugging your base station (where the power and the telephone cable plugs into) leaving it unplugged, get your telephone set and take out the battery.
Put the battery back in your phone and power up your phone.
When the phone is back up and running, plug everything back into the base station... and test your caller id.
The telephone's base station sometimes needs a reboot. There are power spikes on the telephone line every-so-often and can do funny things to your telephone set.
I hope this helps.
May 02, 2009 | Lands Phones
C5180 Ink System Failure CodeOxc18a0206
Here is what you can try:
1. Turn off the power and unplug it from power source.
2. Open the right side of the printer (looking at the front).
3. Disconnect, by pulling gently, both white flat ribbon cables off the main circuit board.
4. Plug in the power source and turn the printer on. Wait till you get a error message and push "OK".
5. Unplug the power source.
6. Reconnect the flat ribbon cables by aligning and carefully pushing them into the conectors on the main circuit board.
7. Plug in the power source and turn the printer on (Printer preparing occurred).
8. The 0xc18a0306 error should now be gone.
http://www.fixya.com/support/t5587774-hp_photosmart_c5180_ink_system_failed
Feb 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
Error message 222aO-reset power come on when I turn on printer. I have plugged and unplugged all cables and power sources.Any solutions to this?
hi,
the error message you encounter is new to me. however, you can try to partialy reset your printer.
1. while the unit is turn ON, unplug the power cord from the back of the printer
2. press and hold the # and 3 buttons together and dont release.
3. while holding the two buttons, plug-in back the power cord from the back of the printer.
4. wait for a couple of seconds, it will give you a message on the printer screen "PARTIAL NVM RESET".. when you see that message, you may release the two buttons.
5. in some cases, after you plug-in the power cord button frmo the back of the printer, the printer will become ONLINE.. and after 30 seconds it will automatically turn off. when that happens, just release the two buttons and press the power ON button to turn it ON.
6. after turning it ON, it will give you message "PARTIAL NVM reset".
note: after performing the steps, your printer will make some noise and it will eventually stops. then try to check if you still have that error message.
- adonscott -
HP TECH
Jun 29, 2008 | HP Officejet 5610 All-In-One InkJet...
1,638 people viewed this question
old marine
old marine
Muntejaya Ginting
Muntejaya Ginting
Ekse
