One is the coldest setting
set it higher say about 1/2 the adjustment of the knob
Possible the fridge thermostat is broken or inaccurate and it is best not to rely on integrated thermometers or temperature indicators as fridges are like ovens and the interior temperature can vary a lot in different places.
Best to use a reliable fridge thermometer. No 1 on the thermostat is usually the warmest setting but be guided by the instruction book and your new thermometer and be prepared to experiment...
SOURCE: Freezer not keeping things frozen
Ice cream requires a significantly lower freezing point than other foods. Keep it near the blowers or coils in most freezers and you'll be OK. Turn up the freezer a bit, and if it is all the way then move it away from the wall a bit more hope this helps!
SOURCE: food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor. It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
SOURCE: food freezing in the refrigerator side
hi! you already the solution of the food freezing problem.the cause was occurs because the thermostat was not duly calibrated..it recommended for calibration.
SOURCE: My Kenmore Elite refrigerator keeps freezing the food!
Replace your thermostat and will work like new again
SOURCE: Ice build up inside refrigerator Liebherr K3150
may be you have a bad temperature sensor or bad control board.
