Hi Zihaalsan,
Normally Sharp Error Codes are 4 characters. It should be E7 and then 2 more numbers.
The E7 family of codes could be a duplex issue, a Laser issue or a few other options. You won't be able to clear the error code on your one. I suggest calling on a local dealer to assist.
If you give me the rest of the code I can tell you exactly what is causing it.
SOURCE: sharp AR-5316, showing L6 on display
The L6 code means trouble with the laser unit ( polygon motor), it has to be replaced. The laser unit is under the exit tray. Hope this helps.
SOURCE: E7 problem
Sharp AR-5132 won't print
Error code E7 13
It will warm up like it's about to print or scan then error code E7 13
please give any advice
SOURCE: sharp ar 407
Hello sir;There have a procedure to reset;
1, press "program", "interupt", "clear", "interupt"
2, enter 14, then press start,then enter 0, press start again. then press clear.
SOURCE: sharp ar-m205 error code E7 11
U HAVE TO UPGRADE THE FIRM WARE BY ENTERING SIMULATION 49-1 THE VALUE IS d THEN UPDATE THE FIRM WARE IF U HAVE IT
SOURCE: help me to resolve an error code E7 in copier
How to solve the error code E007 system error in copier
