Televison & Video Logo
B
Brandi Ygdevik Posted on Aug 01, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Panasonic TV, TC-P50S2.Yamaha DVD Player DV-C6280.Yamaha Receiver HTR-5450.DVD audio working fine thru receiver. Not sure where to place white/yellow cords to get video feed.
Help
The Wyzzyrd
Level 2:
  • Expert 108 Answers
  • Posted on Aug 10, 2016
The Wyzzyrd
Expert
Level 2:
Answers
108
Questions
0
Helped
29951
Points
255
Hello. Usually when you mention white and yellow, there should be a red also, the red and white are right and left audio and the yellow is the video. The audio should be connected to the receiver, and if the receiver has video inputs and outputs, that should be connected to the same receiver input as well, but if the receiver doesn't have video capability, the yellow should be connected to the TV video input. I hope that helps.
5 Related Answers
Anonymous
  • Posted on Nov 29, 2008
SOURCE: DVD plays only in black and white
Hey, I had this problem on Thanksgiving Day, trying to watch a dvd on my mother's HDTV. You should be able to hook up most standard dvd players to hdtvs. First you have 3 cords, mine were red, yellow, and white. The connections go as follows:
HDTV:
Audio| Component. The white cord should be in a white audio slot. The yellow cord should be in a yellow component slot (video) and the red cord should be in a red video component slot labeled Pr/Cr. Make sure you match the component numbers. For instance, if you want to use component one, then hook all of the cords into the slots for component one. Most hdtvs have multiple component hookups ( think multiple "channels" for your game system, dvd player, etc) so it's important that the corresponding cords go to the correct component slots.
DVD:
Match the yellow and white cords to the appropriately colored slots. The red cord should go into the slot labeled component video out Cr/Pr. Not the red audio out. This worked for me. Hope this helps.
Anonymous
  • Posted on Feb 17, 2009
SOURCE: connect dvd home theatre system to bravia lcd digical tv
Amongst 3 audio and 3 video options on DVD, use only one for displaying picture on TV and one for getting sound.
Yellow Wire is for picture.
Red Wire is for sound.
White Wire is for sound.
Connect Yellow from TV to yellow at DVD
Red from TV to Red at DVD
White from TV to White at DVD
Hope this help.....
hometheaterstore.com
Anonymous
  • 205 Answers
  • Posted on Oct 15, 2009
SOURCE: How can I get tv audio thru my surround reciever
check to make sure you connected the RCA jacks to the audio output on the tv then go to the set up menu on the tv and select external speakers
Anonymous
  • 1622 Answers
  • Posted on Jun 24, 2011
SOURCE: Blinking red power light on my Panasonic Viera
Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this helpout to solve the problem...
gopakumarg43
  • 76851 Answers
  • Posted on Jun 28, 2012
SOURCE: My 50 inch Panasonic tc-p50s2 wont turn on.
Y-Sustain board should be suspected. For more details, visit this site, named 'Electro-help'. Type in "electronicshelponline.blogspot' to your browsers' search box, and click search. It is a blogspot site in English Language. Sometimes, ads related to each post might help you to get details about the availablity of spare parts and price.
Where to hook up white/yellow input wires from receiver to panasonic TC-P50S2. HAVE audio no video feed on tv
Usually DVD players have either composite or component video out (unless you are using HDMI connections). That means you need three or five RCA plugs connected between the devices.
The usual pattern when using a receiver would be to connect the Red/White RCA cables between the receiver and the DVD player audio out. Then connect the Yellow (composite) or Red, Green, and Blue (Pb, Pr, Y component) video cables between the TV and the DVD player. Make sure the connections match at each end; with component video, it can be easy to mix them up. Not all receivers have composite or component video outputs available to the TV. The Composite video will go to the yellow connector at Video In 1 on the TV. The Component video would go to Component In 1 or 2.
Since you don't mention the model of the receiver or how that is connected to the TV, I can't be sure why you have no video. If you have an HDMI connection between the TV and the receiver, the receiver won't convert the signal from composite/component video to HDMI.
The alternative method of connecting everything would be to connect the DVD player to the TV (both the audio and video), then use the optical digital audio connection from the TV to the receiver or to a digital to analog audio converter and then to the receiver.
Please add a comment with the rest of your A/V equipment for a more solution.
I hope this helps.
How to hook up to panasonic tv & sony dvd player
DVD output (HDMI) to HDMI input on TV will transfer both audio and video from DVD to TV. Audio output on TV to unused Input on Yamaha receiver (Aux, CD, etc.). This hookup will allow DVD and TV channels audio playback through your Yamaha receiver. Remember to test any/all new hookups or connections using minimum settings (volume, etc.), and bring up levels slowly for the initial testing.
Find Blu-ray player compatible with Yamaha htr-5830
Hello James,I have the exact same issue, did you have any luck?
I have a Yamaha HTR 5450 and tried to hook a blu ray player to it. Only choice I had was the Yellow RCA video and red and white for sound. Could not get video to work but could get sound. My older DVD...
Why is it so important to have BluRay audio on an old TV? Or its video into the Receiver?
What purposes are served with unnecessary 'hops' through electronics that can't use it or improve it?
Get the digitsl audio from the BluRay into the HTR and give the TV the best it can accept for video. Your TV probably has a mid-fi RCA audio input, too. The BlurRay has an output for that, too, if you realy want it.
7helpful
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
I'm getting no sound from my htr-5450 reciever
Check the "speaker selector" on the front panel. Make sure A, B, or both are lit up. Also, make sure the "6 ch input" is"off" it's a button right below the volume knob on the right If it's still not working, post a comment and I'll help you troubleshoot further. Hope this helps
Tv built-in dvd player wont play thru surround sound
use your t/v audio out with RCA cables to your reciever input like(vcr in, dvd in, dtv in)
Yamaha - 5650/HTR-5640
Did you try going thru the setup portion of the owners manual? IF you need the manual you can get it online free. I realize sometimes people read the manuals and don't understand the technical jargon. Let me know if you need further assistance thur chat session and i can possibly step you thru it better in real time. Good luck Guru Jay
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
