The air bag light is blinking 1 once then 3 times.
SOURCE: 1995 Ford Taurus Sho 3.2 check engine light blink
Code 33 is EGR opening not detected, this is caused by a plugged EGR exhaust passage in the upper intake manifold, this is a common SHO engine fault, the valve works but the engine does nothing that the computer can sense, since no gas flows, to verify this is the problem open the egr at idle, the engine should almost die, if nothing happens or only a tiny change in idle speed or quality the passages are plugged, if it does stall or get real rough the egr position sensor (usual code for sensor is 32) may be faulty or the valve is sticking. I was a ford dealer tech for 30 years and did quite a few of these, there is a TSB (technical service bulletin) about this problem
SOURCE: i have a code 51 blinking air bag light from my
Hi Branda1, It will have to go to a dealer to repair. Air bags are not something you want to do yourself, very dangerous. Here is what code 51 means.. hope this answers your question.. Cobra
Diagnostic Trouble Code 51—Air Bag Diagnostic Monitor Internal Thermal
Fuse—Fuse Blown Due to Intermittent Short to Ground
Normal Operation
NOTE: The air bag diagnostic monitor contains an internal thermal fuse
that is not serviceable. The thermal fuse is controlled by the microprocessor
inside the air bag diagnostic monitor . The microprocessor inside the air bag
diagnostic monitor will blow the thermal fuse whenever a short on the deployment
circuits occurs. The thermal fuse does not blow because of excessive current
flowing through it. DO NOT attempt to short circuit the thermal fuse with a
circuit breaker or any other type of fuse.
SOURCE: i have a 1998 ford
passenger belt and buckle asembly pretensioner circuit resistance out of range.
Possible Causes
SOURCE: 2006 Ford Taurus air bag
yes it means your airbags are not working. you need to have it put on ford spec diagnostic equipment at your local ford dealer to have it repaired. some small shops may be able to do it, just depends on if they have the right diag equipment.
SOURCE: 95 Taurus Air Bag light is blinking
airbag light on means fault codes stored in the airbag,
so you should read and clear the fault coeds.
