Question about ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip Cortex A8 Android 4.0, 4GB
I cannot connect to the Internet. Tablet says internet Saved. secured with wpa2 and then goes back to authenticating
It will not stay connected to the internet. I have not been able toetup
Posted by Keith Luton on
1 Related Answer
Tammy Alcorn
  • 43 Answers
SOURCE: I can not connect to the internet with this
The answer to your problem is to reset your tablet by going into setting and find privacy tap into it and there are backup and restore sections. There is also a section to reset back to factory reset. Tap into it and it will restore back to work.
Posted on Jul 31, 2013
How do I get it to stay connected to my wireless internet?
Resolving Internet connection problems - Belkin
www.belkin.com/us/support-article?articleNum=10823
BelkinFrom wireless home networking and entertainment, to mobile accessories, energy management, and an extensive range of cables. ... Sign In · Cart0 items; Free Ground Shipping on Orders through December - Details ... How do I find my model number?... Stay tuned for exclusive offers, exciting new products and more.
My android tablet won`t stay connected to wifi network ...
www.askmefast.com > ... > Wifi
My pc tablet wont stay connected to wifi internet help ... read more ... Someone said: i have a belkin router i have just put a security setting on it all the pcs work fine put in the password but my android ..... Ok it is a slow signal using other network .... Irulutablet doesnt work unless i m in the same room with the wireless router.
Android tablet wifi authentication problem [Solved ...
www.tomshardware.com/.../43704-43-android-ta...
Tom's Hardware Guide
Nov 23, 2012 - 20 posts - ‎9 authors
Jan 05, 2016 | Irulu 9 inch Android Tablet PC, 4.2.2...
MY POLOROID TABLET WILL NOT STAY CONNECTED TO INTERNET. SAYS AUTHENTICATION PROBLEMS
Hello, every wireless device works except my new tablet from Acer running Android 4.1.1. ... Yes, I try to connect to the network router. ... You can hide the SSID - once your Android has it as a saved network it will ... gefraenk said: ... Hello all, I have the same authentication problem, worse, I m not sure what ...
Authentication Problem to Connect Android Tablet - YouTube
? 3:05
https://www.youtube.com/watch?v=2wul81jM7Ts
Apr 2, 2013 - Uploaded by Meroy Diniz
If you have Authentication Problem connecting you androidtablet. ... i got a different problem i cant even turn the wifi on, on my hudl 2 it blocked ...
Dec 25, 2015 | Tablets & eReaders
I can't get no is 9" tablet to work on WiFi. It connects and says connected but won't pull up authentication screen to sign on to network so I'm not able to fully use internet
try turning the wi fi off on the tablet and then turn the wi fi back on and try to reconnect.
you may need to set up the encryption. It could be set on WPA2 and the tablet may not cope with WPA2 may need to use WPA1 on router .
Jan 04, 2015 | Tablets & eReaders
I have a Dragon Touch tablet. won't connect to wifi after WEP is entered and accepted/saved.
Are you still using WEP security? Most devices today no longer use WEP as it is inadequate for serious security. Most devices today are using WPA2 security. If you are no using the proper security you will get an authentication error even if the password is correct.
Dec 25, 2014 | Dragon Touch Tablets & eReaders
Wifi connection problem
Need To Double Check Password And Connection Info. One Error Sets The Whole Thing Off As Wrong.
Feb 02, 2014 | Noria 7 Android 4.2 Tablet - White
I can't connect to the internet. I haven't been able to input my password for my router. I can't find the place to type it in.
You may have a connection to your network already saved. Go into settings > wireless. Tap and hold on your network and select "Forget Network". Also note that if you have only WPS or a pin for authentication to your network this will not work on a tablet. You need to enabled WEP, WPA, or WPA2 with a password
Dec 13, 2013 | Mach Speed Trio Stealth G2 Tablet -...
I can't get online with my new tablet. Authentication Problem
"Authentication issue" is a fancy way of saying "I don't have the right password."
Just because the tablet has found/saved the connection doesn't mean it can connect. Most often it's a missing or incorrectly typed password issue. You should be able to go to the wireless settings on the tablet, touch the name of YOUR connection, and enter the password there.
Don't know the password? Unless you changed it, it's probably the string of numbers/digits on the sticker on the rear or bottom of your wireless router (usually at least 9 or 10 digits/characters, but can vary). If you don't know and cant' find the password, check with your Internet Service Provider for help; they can walk you through resetting the password or changing it.
Also, some tablets don't like passwords with special characters in them (@, %, _, etc). In rare cases I've had to log into the router settings and set a less-crazy password so certain devices (eReader etc.) can work with it.
If that is not the issue, please post more information. Thank you.
Dec 02, 2013 | HKC 7" Touchscreen 8GB Tablet 1GHz Android...
ZEEPAD 7" 7.0 Allwinnwer A13 Boxchip Cortex A8 Android 4.0, 4GB Logo
71 people viewed this question
Top ZEEPAD Tablets & eReaders Experts
Harrie
Paul G
Paul G
Ngoro
Are you a ZEEPAD Tablet and eReader Expert? Answer questions, earn points and help others
