Question about Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB
Hismart button not working
I push the HiSmart button on the remote but it does not do anything channel just stays on the dishnet channel I was watching..the YouTube and Vaduz bottoms work though
Posted by Tra hardingr on
I can't get rid of the closed captioning on my Furrion TV
First, I'm not a Furrion representative.
* Check your warranty. Call for support.
*** Following is for information only.***
* Lower right button of your Furrion Remote. Press the (CC) button for the captions.
* Remote diagram (click on PDF file); https://www.google.com/search?q=futvrs1-bl.pdf&ie=utf-8&oe=utf-8&client=firefox-b-1
* Forest River (Forum) caption prob discussed; http://www.forestriverforums.com/forums/f88/furrion-tv-dvd-closed-caption-142943.html
* Indication that customers having problems with remote; https://www.youtube.com/watch?v=jZoMShPzN40
* Features; https://www.youtube.com/watch?v=pzylYzFAImM
* Captioning may come from 3 or more sources.
* TV has CC module built in. You can access it by pressing menu on your TV remote. Follow instructions.
* Cable (or Digital Sat) box. Use the Cable remote to access the "Cable' functions. press menu and follow the instructions.
* Captioning may be on a mandatory broadcast for channel needs. I.E. emergency network, Hearing impaired channel, etc.
* The original movie or clip is broadcast in a different language that has captioning (translation) added in by local TV station (or network)
* Internet (smart TV) click on upper right of video or access with your smart TV Remote.
Aloha, ukeboy57
Additional (related) information;
* How to set up CC; https://www.youtube.com/watch?v=7_KZOhjEScU
* Setting up (RV); https://www.youtube.com/watch?v=merkAbgc6hY
* Demo DV3100; https://www.youtube.com/watch?v=xs3Jq1ADbrc
* Demo FEHD19SOA; https://www.youtube.com/watch?v=4DwyuYCW9r0
* Demo FEHST8A; https://www.youtube.com/watch?v=s4AIi7mwtVY
* Demo FEHS32D9A; https://www.youtube.com/watch?v=bopMRTfYhcU
* Setting up RV TV; https://www.youtube.com/watch?v=Gs-Kngvf7fI
Aug 18, 2018 | Furrion Televison & Video
My proscan tv volume and power won't work with the dishnet remote and the tv remote died. I put in new batteries and still nothing. Help please
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. In some cases, the remote control might need to clean.
http://remotesearch.blogspot.com/
Search the site by type in this key phrase "how to test a remote control "in the "search box at the top right of the display window of the Homepage" to get the related post quickly.
https://youtu.be/wUpnETSm6_k
https://www.youtube.com/watch?v=jsSCNCW3IbQ [open and clean]
https://www.youtube.com/watch?v=Qp-l1uh-5gE [open and clean]
Apr 12, 2017 | Proscan Televison & Video
My channel Master will not respond to the remote nor to the button on the front of the device. The light stays on permanently.
Check the remote control for its infrared emission. Check it with fresh batteries. Check it by pressing all the keys. You can detect the presence of infra-red emission from the remote control, using a cell-phone camera. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience. In some cases, the remote control might need to clean.
Nov 15, 2016 | Channel Master Televison & Video
Brunette remote will not Turn to the Internet
if this is apart of a smart tv may i recommend to make sure you can tell the difference whether or not you are experiencing a software related issue with the tv or b a hardware related issue with the remote. ( what will need to be done is the tv will have to have the power cord physically removed from the television. wait roughly 2 mins. once this is done plug it back in. the device will boot back up. once the tv is back on pick up the remote and try the process all over again. let me know how you make out.
Nov 04, 2015 | Televison & Video
Need remote codes
I have DirecTV and I have the same remote and I read somewhere you can use the codes for Sampo. I found the codes in the DirecTV remote's manual. The first one I used worked. Hope this helps!
Dec 30, 2008 | Cyberhome CH-DVD 300 DVD Player
I need the 3-digit setup Code for Trutech T650-DR DVD
Note: In order for you to watch your TV your TruTech T650-DR must be on. Not shure what you mean by code? but setup go,s like this.
Out DISHNET to in on your Trutech T650-DR
Out TruTech T650-DR to in TV Note: the name of the input on your TV video 1 or video 2.
Just like your DISHNET you need to be on Ch 3 or 4 what ever is open.
turn on your DISHNET and your Trutech T650-DR Do you see a Trutech logo on your TV?
If yes, Keep pressing the source Button on your Trutech T650-DR remote Tell you have a TV Ch. then press the return button.
use your DISHNET remote to watch your tv.
thats it hope I could help.
Jan 31, 2008 | TruTech T650-DR DVD Recorder
[2] 811 dishnet receiver
you need to program one remote with a different code, power off or unplug one of the receivers. Go to the other receiver and hit the system info button at the receiver. Now read the remote code at the bottom of screen would be a number between 1 to 15. Program the remote for a different code than what it shows. Push and hold down the sat button on the remote and leave go light will blink, enter code say 14 and the pound key. You will see the light blink 3 times on the remote. Now that code is entered in the remote now with that system info screen up on the tv watch at bottom where code is and hit the record key on remote and you will see it change to 14. All done . now just plug back in your other receiver.
Nov 18, 2007 | Televison & Video
ILO-26HD remote problems
I have the same problem.
Nov 06, 2007 | iLO 2600 Television
Need remote codes
I have a CyberHome CH-DVD-300 unit with a Dishnet remote. The remote code that worked for me is 724.
Sep 24, 2007 | Cyberhome CH-DVD 300 DVD Player
Open Questions:
See all Hisense 50 Class 1080p LED Smart HDTV - 1920 x Questions
Hisense 50 Class 1080p LED Smart HDTV - 1920 x 1080, 120Hz, 2000000:1 Dynamic, 4x HDMI, Built-in Wi-Fi 50K610GW-RB - 50K610GW-RB Logo
315 people viewed this question
Top Hisense Televison & Video Experts
Sean Burke
Sean Burke
David Tickner
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
