I need a code for my RCA TV
Im using a tcl tv and i have a st 620 universal tv remote controll
Wharfdale TVs are rebadged by Argos, so I am unsure of the actual manufacturer, and therefore the control signal scheme that they use.
It might help if you gave the model number of the particular TV, as they could be using several different manufacturers in their range of televisions.
it is unlikely there will be a single code that covers the whole range of Wharfdale Tvs
SOURCE: Universal Remote control code on Sharp 13H-M60
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This
is the user's manual for a Phillips remote control. There is a list of
codes in it. They should be rather universal. There's also instructions
as to how to program it. I believe that there is a way to program it
without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4.
Press the Channel Up button repeatedly (up to 300 times) until the
device could be controlled changes channel. The red indicator blinks,
then stays lit. If you accidentally overshoot the code required, press
the Channel Down button to backtrack through the library until the
device changes channel. Pressing Channel Up changes direction to
forward again. Press and release the Mute button to install the code.
Hope this helps :)
SOURCE: durabrand tv model#BH2004D need code for GE universal remote
The code for GE universal remote for th Durabrand BH2004D is "0157"
SOURCE: Universal Remote Controll Codes for a Zenith TV
These are the codes for Zenith TV: 0121 0009 0050 0078 0091 0138 0059 0131 0038 0111 0134 0153 0064 0004 0135 0226 0227 0245 0247 0252 0266 0288 0310 0338 0358 0023 0058 0039 0001
SOURCE: I need a universl remote code for a wharfedale tv
i need a code for my wharfdale tv 2126 please some one help me contack me on my hotmail address its [email protected] thanks :)
