Question about Magic Chef CER3725AA Electric Kitchen Range
Preheat beep indicator is inaccurate
According to the manual, when the desired temperature is reached, one long beep will sound. Using an oven thermometer, we have found that it beeps at about 30 degrees under the indicated temperature. It does eventually reach and stay at the desired set temperature. The authorized maintance person adjusted the ERC (which I had done myself, so I knew it wasn't the solution). A second service person said that was the way it was designed, due to a federal regulation. I had to refrain from laughing at him. The store where I bought it simply refers me back to the authorized repair people, who obviously don't know what they're doing. Granted, this is only an inconvenience, but any advice would be greatly appreciated.
Posted by purplecar on
  • purplecar Nov 19, 2007
    Thanks for the speedy responses. However, I should have added to my original post that if I put the food in when the oven beeps, indicating it's at the set temperature, I always will end up with an under-cooked meal. So it's neither working ok, nor is my oven thermometer the issue.
    I guess I'll live with the inconvenience.
  • Anonymous Mar 12, 2014
    preheat beeps before reaching set temperature
Anonymous
  • 290 Answers
A standard oven thermometer is not very sensitive. The reason is because the oven temp varies 50-75 degrees during the cycle and you don't need to know this when baking, you just need to know the median temp.
When checking the oven temp, you don't adjust anything until the oven has cycled at least 5 times. It takes that long for the cavity temp to stabilize. Since the temp on your thermometer does level out at the proper temp, I don't think you have a problem with your oven. I would assume they checked the temp with an electronic probe.
Adjusting the temp offset at the ERC is about all you can do without replacing the ERC or sensor if the temp is actually off.
Don't laugh about the federal regulations. The Dept. of Energy set oven temp/cycle time regulations that went into effect Jan '05.
They set regulations on hot water wash temps for new washing machines that just went into effect Jan '07.
Posted on Nov 19, 2007
  • Anonymous Nov 19, 2007
    Don't settle with it if you are convinced you have a problem. Contact the manufacturer. You should have a number in your manual. I am constantly running into customers who put up with something until their warranty ran out and then it caused a worse problem. Contacting the store you bought it from is usually useless unless they service their own product.
    You have a full one year warranty, and I would not settle with it until they had at least replaced the sensor.
    Magic Chef is a Maytag brand, which is now owned by Whirlpool. I know for a fact that Whirlpool would rather have the technician replace the sensor and ERC than to have you call them more than once.
Gerald Griffin
  • 248 Answers
It's working ok. These often beep after a preset time. It may be set to beep at 10 minutes. Not always at the temp set. It is usually close enough though.
Why hasn't the oven reached the set temp when the buzzer sounds indicating desired temp has been reached?
What are you using to measure the temperature of the oven? If you using a typical round oven thermometer, the reason is that your thermometer response is slow. It takes about 20 minutes for those thermometers to reach and display the actual temperature, and your oven is probably reaching it's set temperature in about 10 minutes. You really need an electronic thermometer or at least one of those liquid thermometers which you can sometimes find at Ace Hardware or True Value Hardware stores.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Apr 29, 2015 | Kenmore Kitchen Ranges
How i know if oven reach the temperature i set for baking?
best way is to purchase a hanging oven thermometer it hangs on rack edge and you can view it thru door glass , some of the new ovens beep as well when they reach there setpoint for temperature
Mar 07, 2015 | Ovens
Is there any way to turn off the beeps- starting oven, when it reachs set temp, changing temp
Hello g harrison - Unfortunately the range does not have an adjustable volume level or cannot be turned off. It is designed to advise you of when the oven is starting or reach desire temperature.
Nov 29, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
Oven does not reach set temp
What are using to measure temp ? Are you using a grocery store bi-metal or professional thermal probe ? and further to that, how long are you waiting to check temp. after range "beeps" or announces preheat complete ? The bi-metal type thermometers do take several minutes longer to reach actual temp as opposed to the ranges temp. probe. Does this unit have the "hidden" bake element ? That sounds like a huge temp difference. These units do require an additional 10mins of wait time after announcing ("BEEP") the preheat is complete (check your manual, it should confirm this) Elements don't go "bad" it either comes on (amp draw) or it doesn't.
hope this helps.
good luck
Sep 26, 2009 | Frigidaire Ovens
Oven flashes F2 and beeps in the middle of baking or broiling something. Our oven is all electric and recently whenever we start to broil or bake something, after a little while it will shut off and the...
HI. an F-2 during a baking cycle is the result of an out of control oven temp that has reached Temperatures above 615F-630F
If this actual over temperature condition occurred, Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
If no over temperature condition occurred, Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Remember: Oven control (ERC) measures resistance of sensor circuit , not actual oven temperature.
Aug 04, 2009 | GE Ovens
Incorrect temperature
under the oven knob is the screw that adjusts the temp. remove the knob and with a small blade screwdriver adjust the temp according to your wife's oven thermometer CW+hotter CCW=cooler
then on the back of the knob is a screw to adjust the position of the knob with respect to the marker
Apr 20, 2009 | Viking 30" Professional Select Built-in...
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Preheating Oven
Cold Stove, you may not be able to. The issue here is that oven manufactures put on their units a fast preheat. However it isn't possible to preheat an oven for 7 to 9 minutes and bake short time bake items properly. Also the oven sensor will respond faster than the absorbation rate of the sheet metal in the oven liner. To preheat an oven properly takes 15 to 20 minutes before putting in the food. I see this will a lot of current ovens. Sounds like a normal format of the control.
Feb 03, 2008 | GE JBP24 QuickClean Electric Kitchen Range
Oven seems to be going crazy
You may have a problem with the keypad. I suggest that you review my solution at the following link:
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with over 1470 folks and most report success.
If it works for you please let me know at the following site:
[email protected]
Good Luck
Dec 13, 2007 | GE Profile JKP18 Electric Single Oven
Magic Chef CER3725AA Electric Kitchen Range Logo
415 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Marvin
Marvin
John Tripp
John Tripp
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
