Igloo Cooler Igloo Portable Countertop Ice Maker Logo
M
Melody Kelley Posted on Jul 29, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I drained the water from my icemaker to clean it and put the plug back in. Plugged it in light shows there is power, however the power button will not turn on to make ice.
Power button will not work after cleaning out the water tank and filter.
Nater13
Level 3:
Master:
  • Igloo Cooler Master 610 Answers
  • Posted on Sep 01, 2016
Nater13
Igloo Cooler Master
Level 3:
Master:
Answers
610
Questions
0
Helped
242539
Points
2229
Is the water tank full? Try holding the power button for three seconds...
ICE FORM AT THE BOTTOM OF THE FREEZER ALL THE TIME, LEAKS OUT ONTO MY HARDWOOD FLOORS AND FORM PUDDLES
Step 1: . Unplug the fridge. You can wait until later but don't forget.
Step 2: Freezer door. It's 4 screws, one in each corner. Just loosen them a few turns - don't take the screws out entirely - it's much easier putting the door back on when the screws are already in place. The door slides up & off.
Step 3: Lower basket. It lifts out, no tools required. Now's a good time to start eating all your ice cream.
Step 4: Upper basket. Remove the 2 screws at the front of the rails, then lift up the rails slightly on each side, to slide the basket forward.
On the plastic pieces at the back sides of the upper basket, push in two tabs with your screwdriver on each piece & pop them up. This will let the upper basket slide out off the rails.
Step 5: Icemaker. Remove the lower screw, then loosen or remove the two screws above the icemaker. Unplug the wire harness where it passes through the rear panel - squeeze the sides of the plug & pull. Lift the icemaker up & out. The water tube will slide out of the guide.
Step 6: Plastic guards.The thermostat guard is the skinny piece to the upper right. Push in (to the right) the tab on the left side in the middle. The guard opens like a door pivoting on the right edge, & pulls out.
The center fan guard has two tabs at the top on each end that push in toward the center, & another tab in the middle at the bottom of the guard that pops up.
Step 7: Freezer panel. Remove the 4 screws in each corner. Push the thermostat back through the slot at the top, & also push the icemaker plug back through its slot.
FAST/HARD WAY: Pull carefully up & out from the top middle edge. Be careful because that sucker is SHARP! The back panel will bend vertically in the middle as you remove it, but it's flexible & will pop back into shape.
SLOW/EASY WAY: If you don't like bending the panel around the drawer slides, you can take off the slides. The metal rails have tabs that push in to release the whole slide assembly, which pulls out forward. You only need to take the rail housings off one side - when you go to remove the rear panel, just pull that side first. To release the upper section (that you already unscrewed in Step 4), left it up, bend in & pull out - the back end has a tab through the freezer wall. The lower plastic slide housing unscrews with 4 screws.
Step 8: Ice Dam. By now you should see the ice problem. Typically the entire evaporator tray is completely iced, along with some of the tubing. MELT IT ALL. Warm water applied with a turkey baster works well. Be careful not to puncture the coils because ... that will ruin your fridge.
Do all the ice melting while the drain is still plugged so it runs out into the freezer floor where you can sponge it up. If the meltwater goes out through the drain hole, it can flood the pan under the fridge - no big deal, just dirtier water & more mess.
The drain hole is near the front of the rear tray in the middle. It's pretty wide (1/2?) & short, only ~2 inches long. It goes straight down into a rubber "duck bill" grommet that's probably plugged up with gunk, that you access from the back of the fridge...
Step 9: Drain grommet. Pull out the fridge so you can access the back side. Remove the screws (6?) around the lower access panel, pop the power cord up & tilt the panel out of the way. The plastic tray under the fan is the evaporator tray - that's where the water SHOULD normally be dripping into & evaporating from.
Behind (technically in front of) the fan, there's a black drain slide into the tray that leads up to your plugged drain. Push the slide aside to see the drain. There's a rubber "duck bill" grommet on the end. Pull it off & clean it - it's no doubt plugged with gunk. Better yet, trim the opening very slightly so the hole is larger - see this site for photos.
Step 10: Put it all back together. Some tips: if you lived hard/fast & didn't remove the rails & rail housing, getting the freezer panel back in place . Make sure you slide the tray rails all the way out before you start trying to put the rear panel back. Bend the panel vertically along the middle so it springs back into place on each side. Again, wear gloves. Once it's in place, don't forget to run the thermostat wire & icemaker tube/plug out.
When you put the the top tray back, make sure it's all the way to the front before you pop the plastic pieces on each side back down, so the gears on each side are aligned in matching grooves. Otherwise your drawer will be crooked & probably won't slide.
Hope this helps. I have a Whirlpool GX2FGDXVY but these steps work on other models too including Maytag etc.
here is the whole exert video of the whole eplanation watch it,(https://youtu.be/lhuBR1sKx7E)or
kingsley
2answers
True freezer
check the condenser and freon
Model # FUF17DACWH Freezer is leaking water
After the defrost mode, the water from the melted frost or ice should go down the drain at the bottom back of the freezer compartment. That drain is probably plugged with some gooey gunk. If its an upright freezer, there will be a hose clamped to the back that comes out of a plastic fitting.. detach it there and 'fish' into the plastic fitting with a short piece of wire then blow into it to dislodge whatever may be there. Blow downward on the hose as it too could (probably not) be plugged between there and the drain pan under the bottom of the refrigerator.
Severe cases require that the freezer back be removed and the drain thoroughly cleaned. That gets real tricky, but its doable. Ice makers in the way complicate the process too.
Kelvinator fridge freezer
  • If your refrigerator leaks water, you have a problem with either a water line or a drain line. If your refrigerator has an automatic icemaker or a water dispenser, the water supply line could be broken. Automatic icemakers have a drain line that runs down to the drain pan beneath the fridge. Mold build-up inside the drain line can lead to a rupture that allows water to escape .A broken drain line can also lead to water leaking from your refrigerator.
Dec 16, 2013 • Freezers
Kenmore refrigerator with a bottom freezer leaks water on floor
Hello Wayne,
You already mentioned the reason for the excess water. When the freezer automatically defrosts itself once every 24 hours the melted water drains down through a tube down to a water pan at the bottom of the refrigerator where it sits and supposedly evaporated by the fan back into the atmosphere. However in your case the excessive dust is preventing the evaporation phase to occur by the fan. You need to vacuum as much of the dust as possible and your problem will disappear.
Good Luck
Rich Lilja
1helpful
Danby icemaker DIM3225BLSST, having drainage issues and trying to troubleshoot. Is the drain pump switch on if the "O" is selected, or the "----" ?
Thank you for being very descriptive. I would get the installer back out since it is new and probably still under warranty and instruct them to say with it until it has satisfactorily run a couple of cycles. They can easily troubleshoot this machine while they are on the job.
I have a Kenmore Model # 253.62812202 refrigerator. It collects water at the bottom of the vegee and fruit trays at the bottom of the refrigerator which eventually leaks out onto the kitchen floor. Does...
It has a clogged drain tube and bottom trays is already full.
De-clogged it using a solid wire, match enough to penetrate the drain tube.
Insert solid wire slowly to the drain tube, back and forth.
Put water to clean and rinse drain tube.
Regularly check drain tube for clogged and tray for full water.
Good luck.
My subzero 601 F freezer door gets hard to open unless you wait 4 minutes. While investigating this I discovered that there is a buildup of ice in the trough behind the icemaker. It appears that the drain...
switch off machine. open doors an manually defrost.clean any filters/drain holes(wire is not heated,pull/push to clean pipe)dry as best you can.switch on again.it is best to manually defrost any unit every 6 months and if temp edjustable adjust to -20c for optimum economy.water to icemaker is not important on 601f but is on some others.be carefull
Feb 06, 2010 • Freezers
Items in freezer melting, Ice maker empty, fridge feeling warm
hi there,
you have 2 problems:
frist check the freezer thermostat and make sure that it's set to at least 5 or 6. if that is okay and you still have this problem, you may need to have the thermostat replaced and maybe more.
as far as the icemaker, if it's just the ice part that does not work, i would recommend checking the valve and water line coming into the icemaker.
can you tell me if this is a side by side or a top or bottom mount freezer? if you have the model #, that would be great.
Top Igloo Cooler Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you an Igloo Cooler Freezer Expert? Answer questions, earn points and help others
