Question about Gaggia Synchrony Logic RS
I just got a new Gaggia Synchrony Logic RS from amazon and it only leaks water when we turn it on?
We just got the machine and even when we put in the water and coffee beans, only water leaks out from the back. We have another one and it works just fine. How can we fix it?
Posted by Marion Wu on
Bill Boyd
    Top Expert:
  • Gaggia Master
  • 53,816 Answers
Brand new --out of the box-- still covered by warranty --don't fix --contact your supplier and ask for a return of defective item and a refund or a new unit as replacement
Posted on Jul 29, 2016
Gaggia synchrony logic making grinding noise
With these removable units, you must be very careful, the circular mechanism that does the running of the Y motion need to be properly alligned. You need to perhaps put the back of a knife in it and adjust until all the parts align, Then it must click in easily. If you have forced it in the clip will not release. you need to rattle it a little.
Sep 02, 2012 | Gaggia Syncrony Logic 74884 Espresso...
My Gaggia Synchrony is leaking - If I remove the water catch basis, I can see a drip. We have used this machine every day for years - can the problem be fixed easily?
HI
There is a panel behind the brew unit, that has 2 screws. Remove it and clean the coffee residue behind it. That is what drains the pressure relieved after brewing, and has coffee residue that can build up and cause the leak. It should leak into the drip tray though, except when you rremove it.
Oct 23, 2010 | Gaggia Syncrony Compact Coffee...
Gaggia Syncrony logic rapid steam machine leaks water from bottom
Check the chamber under the white plastic valve behind the brew unit, it might be blocked with coffee.
Apr 13, 2010 | Coffee Makers & Espresso Machines
Where can I purchase a replacement dispenser shute for Gaggia Synchrony Logic Type SUP 020 Ser.#9005GA40015808? Many thanks.
Check the site at importika.com they have a list of repair areas any one of them will have a spout in stock.
Mar 10, 2010 | Gaggia Syncrony Logic 74884 Espresso...
Gaggia Synchrony wont work after decaling
Check the thermostats on the boiler and the boiler element?
Jul 14, 2009 | Gaggia Syncrony Espresso Machine
I have a Gaggia Synchrony compact. I recently decalsified it and it stopped working. The low water light is on and nothing works except, for the water pump. It will flow only cold water through the steam...
If it leaks from the steam wand then you need to get a new steam valve assembly. For the heat you will have to open the machine it is possible that the steam boiler is damaged or that the thermostat on there is bad, use an ohmsmeter to check thermostats and element. There are 2 screws in the grinder, 2 behind the water tank and about 2 or 3 in the front behind the door.
Jun 09, 2009 | Gaggia Syncrony Compact Coffee...
Gaggia Synchrony - we need a new boiler.
http://www.cafeparts.com/dynamicIndex.asp This site has parts.
Feb 16, 2009 | Gaggia Syncrony Espresso Machine
Gaggia Synchrony Compact Digital Problem
I think you have get air in the system, try to find a bellows pump or similary. Fill it with water, open the steam knob and take of the water tank, put the pump in the water inlet and press. When the water begins to flow, close the steam knob and put the water tank back.
Best regards
/Mirran
Nov 01, 2008 | Gaggia Coffe Deluxe Coffee Maker, Espresso...
Gaggia Synchrony Logic RS Logo
96 people viewed this question
Top Gaggia Office Equipment & Supplies Experts
Marvin
Marvin
Are you a Gaggia Office Equipment and Supply Expert? Answer questions, earn points and help others
