Jess De Revere Posted on Jul 28, 2016
Phaser 8550 is showing paper jam in tray 2. No jam. Message won't clear. I've removed all trays, opened front of machine, restarted it, turned it off and unplugged then plugged in and turned back on.
Paper jam message will not clear
namam
Level 1:
  • Contributor 7 Answers
  • Posted on Aug 08, 2016
namam
Contributor
Level 1:
Answers
7
Questions
0
Helped
2321
Points
10
Probably an actuator has fallen off or broken on one of the sensors
3 Related Answers
Thomas F. Schneider
  • 2715 Answers
  • Posted on Jan 04, 2009
SOURCE: Paper Jam detected. None found.
Here is the Xerox support page for your printer. It even has a movie on removing paper jams.
http://www.office.xerox.com/perl-bin/product.pl?page=sprt&product=8400&country=United%20States&language=en#_manuals_and_documentation_
Anonymous
  • Posted on Jan 12, 2009
SOURCE: Jam at top message will not clear and no paper in path
Hello Al_edee,
Try to look at the fuser, when it's cooled down, if there are remains of old or stuck paper in it or to exchange the fuser.
Kind regard,
Mark
Anonymous
  • 160 Answers
  • Posted on Apr 06, 2011
SOURCE: Xerox Phaser 7700 laser printer problem. Display
If your Xerox phaser 7700 7750 or 7760 is having a Paper Jam at A-Fuser error, this video should help. Good luck
My Phaser 8500 will not print and has error 08,045,43:75066 - Anyone know what this means?
The Xerox support site indicates there is a paper jam to the printer, so you should check the paper tray, front and exit cover for any jammed paper then power off and back on the printer. Have a look here: http://www.support.xerox.com/support/phaser-8500-8550/support/enus.html?operatingSystem=win7x64&fileLanguage=en
18helpful
2answers
I'm getting Jam at Reg Roll on my Phaser 6180, and I think there may be a bit of paper in the paper path, but i can't see it. The machine says Open Door A, which I've done a few times, but it isn't...
Had exactly the same problem... today actually.
Found the solution with another model's manual - I removed the paper from the top, but hadn't realised there was a jam in the paper tray. It was only when pulling it out completely that I found it as below...
Jam at Registration Roller
1. Remove Tray 2 completely.
2. Clear the jammed paper from the printer's
intake slot.
3. Re-insert Tray 2.
4. Open front door A.
5. Remove jammed paper if present.
6. Close front door A
1helpful
2answers
Error e03, but there is no jammed paper
E, 0, 3
Paper Output Tray is closed / Paper jam
Summary
If the Paper Output Tray is closed, open it. The machine resumes printing.
If opening the Paper Output Tray does not resolve the problem, or if the tray was open to begin with, the paper may be jammed. Remove the jammed paper, reload paper properly in the printer, then press the Black or Color button.
E, 0, 3
Summary
E, 0, 3
Summary
Techbelkin
Keeps telling me to remove back tray as I have a paper jam. No paper jam. Message won't clear and won't let me put in new ink cartridges which it needs....printer is 2 months old....what gives?
You did not post a Make/Model but with many machines they will have a trap door/panel at the rear of the printer. If paper did not pickup from paper tray properly then it will show a jam message that can only be reset by opening the rear door/panel.
1helpful
2answers
Paper jam and still won't print
Hi
Thanks for using FixYa. Before you can clear the error message, you must locate where in the unit the paper is jammed.
Unplug the machine for safety. Now follow these instructions based on where the paper jam is located.
1. Pull the paper tray out of the machine.
2. Pull out the jammed paper.
3. Reset the machine by opening the Upper Jam Clear Cover and then closing it.
If you cannot remove the jammed paper from the front of the machine, or the error message still appears on the LCD after you have removed the jammed paper, please go to the next step.
4. Remove the Lower Jam Clear Cover from the back of the machine. Pull the jammed paper out of the machine.
5. Put the Lower Jam Clear Cover back on. Make sure the cover is set properly.
6. Open the Upper Jam Clear Cover. Make sure that there is no jammed paper left in the corners of the machine.
Note: If the paper is jammed under the print head, unplug the machine from the power source, then move the print head to take out the paper. 7. Close the Upper Jam Clear Cover.
8. Close the output paper tray cover and slide it forward, then push the paper tray firmly back into the machine. While holding the paper tray in place, pull out the paper support until it clicks and unfold the paper support flap.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
6helpful
3answers
PAPER JAM ERROR 201.02
if you are gettiing a 201 error without any paper in the printer you will need change the main motor drive if it fails to initialize this is the error that will show up and there is no other way to reset it
1helpful
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
