I just finished replacing my DLP chip and i repeated the process about 5 times because when i try to turn the tv on the screen doesnt go on, and the audio cannot be heard. All i was able to see was the the fan would turn off about 10 seconds from pressing the power button, then the tv shuts down. I kniw the DLP is adequately installed, i am thinking i wired it incorrectly. Please help.
There are some adjustments should be done after the DLP chip replacement. If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
i had the same lines on my 65' mitsubishi tv after replacing the DLP chip. after going back over everything i realized that the casinf that holds the chip in was not in the lock position. i took the chip out and replaced it then turned the little locking mechanism to the locked position. now my screen is perfect. hope this helps.
White dots on your RPTV television are the result of the DLP chip being worn out. You can replace it very easily by buying a new DLP chip for just under $190 and installing the new chip. There is a very good forum over at fixyourDLP that offers tutorials for replacing the DLP. http://www.fixyourdlp.com/2012/10/11/banish-white-dots-from-the-samsung-hl56a650c1-with-a-new-4719-001997-dlp-chip/ or for Mitsubishi http://www.fixyourdlp.com/2012/10/02/install-a-new-4719-001997-dlp-chip-and-banish-white-dots-on-the-mitsubishi-wd-82737/
Mitsubishi that the one,who u should contact.Talk to them make some kind of deal with them to help u to do a repairing or replace the tv Light Engine Projection Block.That the tv problems,this problems a design flaw on the tv Light Projection Egine Block the IC they put in that causes of this white spots are showing up will continue showing up more and more white dots.It will not stops.
Mitsubishi is currently offering the following parts
Model Number
Model Description
Part Number
Part Description
Price
Available
WD-52631
52" DLP TV
I/B WD52631
OWNERS GUIDE
$15.00
YES
WD-52631
52" DLP TV
I/QR WD52631
QUICK/REF WD52631/57731/65731 'G'
$3.50
YES
WD-52631
52" DLP TV
915P049010
LAMP (150W) (V33/V33Y/V33+) 'G'
$249.00
YES
WD-52631
52" DLP TV
290P137010
REMOTE 'G'
$33.10
YES
