Unit blows cold for a few minutes and then blows hot air
SOURCE: no heat
1.check heatar of unit.
2.wireing of heater.
heater not workink.
thermostate also check
SOURCE: Amana APO95R Turning Off/Tank Light (!) On and Off
There are only two items that will shut it down after it is set to run. The bucket full which you took care of and low humidity in the area it is being operated in. Low humidity would not constitute a reason for returning it.
SOURCE: no cool air. blowing warm air
is breaker for condenser tripped---has it been running before -----is fan on outdoor ubnit running?
SOURCE: Blowing of cold air every 5 minutes, and it says FP on the screen
FP is the code for frost or freeze protection. The unit will automatically do this periodically to prevent any damage caused by low temperatures although it should not be running as frequently as every five minutes. If the outside temperature is not low then it could either be a problem with the exterior thermistor (not the one you see from inside your room) or the control board could be on its way out.
