Question about iPhone 5c Cell Phones
I changed my iPhone 5c battery, now the display has lines and squares on it and the touchscreen is slow to respond , off at all. How do I fix it?
Posted by Shannon Lambeth on
  • Susanewman
    Susanewman Nov 24, 2021
    [ JOIN US ] I get paid more than $60 to $70 per hour for working online. I heard about this job 3 months ago and after joining this I have earned easily $10k from this without having online working skills . Simply give it a shot on the accompanying site…
    Here is I started.……......>> http://Www.NETCASH1.Com
August Brown
    Master:
  • iPhone 5c Master
  • 495 Answers
Maybe the FPC is loose. You need to check again all FPCs connection. If your iPhone still running slow, see: How to Fix iPhone Running Slow?
Posted on Nov 24, 2021
john h
    Top Expert:
  • iPhone 5c Master
  • 25,745 Answers
Put back togeather improperly ribbon wire possible pinched or out of place causing screen problems]
Posted on Jul 28, 2016
I can't get a full charge that will last on my Iphone 5c
what is your problem exactly. your iphone wont charge fully at what percentage it stop like 90 %.. it may possible that your battery one or two cell not working and that is why it want able to fully change. here is how to do ipad iphone troubleshooting. try to restore iphone to latest version of ios 11. remove your battery then clean connector point of your battery and then reinsert battery.
check your iphone with other battery and then check whether it fully charge or not. also
http://ipodtips-tricks.blogspot.com/2017/09/ipad-iphone-troubleshooting-guide.html
2answers
How do I insert SIM card?
Use the pin provided to push in the hole on the side of the phone and a sim card tray will pop out
3helpful
4answers
My iphone 5c stopped working suddenly, its screen darkened and it does not work. What is the problem?
Reset the phone:
  • Plug the charger into the phone.
  • Hold down the Home button while holding down the On/Off button.
  • Continue holding these down until (hopefully) the Apple displays on the screen.
2answers
My touchscreen on my iphone5c isnt working
Power down completely. Power back up. Hope for the best. Good luck.
How do i open the battery of iPhone 5c
If you mean, replace the battery, its fairly simple. but you must have special screwdrivers to remove the screws, you can get these, as well as a replacement battery very cheap on ebay. here is a guide to disassembly and replacing the battery on an iphone 5c :)
http://www.imore.com/how-replace-battery-iphone-5c
2helpful
4answers
How to tell if an iPhone is a 5 or 5S?
The physical differences between the iPhone 5 and 5S are the camera flash and the home button. iPhone 5 has a single LED flash while the iPhone 5S has a dual LED flash. And the iPhone 5 home button doesn't have the circular ring around the button which is the finger print sensor unlike on the iPhone 5S.
2answers
How's the new Apple iPhone 5C different from the iPhone 5?
The new Apple iPhone 5C is very similar to the iPhone 5 both in software and hardware. The real difference between the two is their appearance.
Differently from the older iPhones 4s and 5, and the newer iPhone 5S, made of alluminium and glass, the iPhone 5C has an outside structure of polycarbonate, which makes the phone more resistant and similar to other plastic-based phones. Another big change was the color range. The iPhone 5C comes in 5 different very bright colors, only seen on iPods before.
2helpful
4answers
Iphone touchscreen not working:(
I think my solution for my Viewty will work for the iPhone
I found a solution for the LG KU990 Viewty touchscreen not responding problem. After thinking about twisting my phone, I came up with another solution which actually works every time. The touchscreen works via layers of plastic that when contact is made, a signal is triggered from the coordinates of the contact. However, when the phone has pressure, these layers of plastic stick together somehow. So, to fix it.... Get a small strip of adhesive tape that will not leave a sticky residue on your screen. Apply that tape in several spots on the surface of the screen, and lift it away from the phone with light pressure. Repeat this in several areas of the screen. That's it. You're done. Your screen should function properly. Simply recalibrate the touchscreen at this point in your settings menu. I hope it helps everyone with any type of touchscreen. I know it helped me. The touchscreen phones are totally useless using only the hard keys!
Kenny N
Cell Phones Logo
Top iPhone 5c Cell Phones Experts
john h
ADMIN Canada
ADMIN Canada
Kolbrun...
Are you an iPhone 5c Cell Phone Expert? Answer questions, earn points and help others
