Krups FBC4 1600 Watts Toaster Oven with Convection Cooking Logo
Question about Krups FBC4 1600 Watts Toaster Oven with Convection Cooking
I need a Manual for a Krups Counter Convection Oven
Posted by Audrey C. Braun on
  • Krups Master
  • 6,611 Answers
Krups has one manual for the FBC2, FBC3 and FBC4 models. Start here: http://www.krups.com/Consumer+Services/Product+Support/Manuals/Use+Intructions.htm and use the drop-down menu on the left to select Toaster Ovens. Then select the FBC2. Click on the green and black icon to download the manual. The direct link to the manual is http://www.krups.com/NR/rdonlyres/5605B757-078E-4DF1-9DED-A884209066C8/4351/TOASTOVENFBC234_usa.pdf . The manual is also available here: http://static.highspeedbackbone.net/pdf/TOASTOVENFBC234_engusa.pdf . You can also get this manual from the Krups FBC2 product page: http://www.krups.com/All+Products/Toaster+Ovens/Products/FBC2/FBC2.htm . Click on the Instructions link.
I hope this helps.
Posted on Jul 27, 2016
2answers
I need the manual to counter top oven model #31197
People keep asking for this even though there are others (now mostly dead links) so I have posted it (3 language edition) here:
http://66.39.50.3/Manual.pdf
I have a fbc2 krups convection oven and the handle is broken. is there a replacement for this?
Molly, there appears to be some replacement parts available:
this is a link for the oven door and handle, which appear to come together: http://www.smallappliance.com/product.asp?pid=2478&cur=USD&sid=18956&gid=18984&pfor=2805&shopBy=Category this site is referenced as authorized by Krups, but Krups did not show this replacement part in their online store.
this is a link for the tray handle: http://www.krupsonlinestore.com/product_detail.asp?T1=KRW+SS%2D185298&MENU=parts&SELECT=toasterovens&SKW=PARTFBC2 for 1.99 from Krups, and http://www.smallappliance.com/product.asp?pid=2479&cur=USD&sid=18956&gid=18984&pfor=2805&shopBy=Category for 8.99 from smallappliance.com, referred by Krups.
Hope this is helpful.
3helpful
My Krups FBC 1 toaster oven has a broken spring for the glass door.
Most of the time a hardware store will have a variety of springs or try home depot.
That's if you only don't want to wait for a manufactors spring.
27helpful
Setting clock on krups toaster oven
When the oven is first plugged in "12:00" appears on the display.
• Press the "Timer" button twice. The display will begin to blink "12:00".
• Adjust the time in steps of one minute by pressing the "+" or "-"
buttons.
• If you hold the button pressed down for more than 6 seconds, the
time will change quicker.
• Press the "Timer" button to enter the time in the system.
If you do not press the "Timer" button, the time will be
entered automatically after 30 seconds.
8helpful
Convection Toaster Oven won't turn off
you have a relay failure . its real common on all digital ovens in general after looking up yours , there are no inside parts made for this oven . this is another problem with all "made in china " appliances THERES JUST NO PARTS! anywhere ! see what your warranty will do , if thats no good, some krups appliances can be sent back for "repair " its not realy repaired just replaced at a reduced cost . i wish you luck .........Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob .
16helpful
2answers
Quartz heating elements problem in Krups toaster oven
you can touch the element but be carefull the glass is thin .... so scrape it and do what you can . THEN USE A COTTON BALL AND ALCOHOL and clean the element that will get rid of the oil you left behind ,you will be fine ......Please if this answer helped , please rate this 3 or 4 stars . and keep me in the paid answer department . A 1 or 2 may knock me down into the unpaid ranks. Thanks Cactus Bob
1helpful
2answers
How can I turn off the annoying "beep" on my Krups Toaster Oven?
Check out this link; might or might not help you:
http://applianceguru.com/forum1/15129.html
Please post whether this works for you.
Good luck, Sam
1helpful
Krups 296 Toaster Oven will not heat
Fusible link inside the unit is probably broken.
Krups fbc2 toaster oven cuts off while toasting
returned it to vendor and asked for exchange.  decided no way I should fix it after less than 5 days of use.  Curious if others have encountered a similar problem.
Top Krups Toaster Ovens Experts
Marvin
Marvin
Stan Ford
Are you a Krups Toaster Oven Expert? Answer questions, earn points and help others
