Golf Logo
A
Allan Howie Posted on Jul 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do i increase the speed of an electric golf cart?
  • Ronald Prier Oct 22, 2016
    Hi Allan Howie, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What kind of cart? Make, model year?
Level 3:
  • Master 19,187 Answers
  • Posted on Oct 22, 2016
Master
Level 3:
Answers
19187
Questions
0
Helped
4339583
Points
82259
1 Related Answer
golfcartman
  • 34 Answers
  • Posted on Mar 03, 2015
SOURCE: I bought a 2010 zone electric cart and it will not run but about 20 minutes on a full charge can anyone help Please
Have the batteries tested using a load meter. Advance and Auto Zone can test them for you. If batteries are 6 years old or older, you will be looking at a new set. A LOAD test is the only way to test.
Is it possible to speed up an electric golf cart?
Most electric golf carts run on a max speed of 12MPH. It all depends on the voltage. The higher the voltage, the faster the speed. Most electric carts out there run on either a 36 or 48 volt operating system and can only last about 20-25 miles per each charge.
There are some new carts coming to market that are able to travel faster and possibly on less energy and can go up to 19 MPH. Many of the latest models are operated by computers and have quite a few high quality and unique components compared to older trolleys and carts. If you want or need something faster, they are worth look into.
Aug 17, 2018 • Golf
1helpful
2answers
Electric club golf cart is very slow especially up hill batteries replaced I last 18 months has made no difference
  1. You did the right thing, you almost always start with the batteries first. However, it may be the controller. The speed of an electric golf cart is determined by the speed controller. Problems with this part may be trickier to diagnose and repair. This YouTube video shows you how to replace one: https://www.youtube.com/watch?v=azWblmoGAJs I hope this helps you out! Rhonda
Oct 27, 2017 • Golf
How can I Speed up my 2004 Yamaha 36 v golf cart short of changing motor
If you are getting full voltage to the motor and that is the best you can do, then you have no recourse other than to change the motor.
Mar 31, 2017 • V Golf Golf
Electric golf cart won't run on cold mornings. I hear solenoid click but nothing happens. When the temp warms up, it runs normal. I replaced controller, solenoid, speed control and ITS & switch.
Depends on how cold it's getting outside. Cold weather is ******* a battery. Try load testing your batteries. That "clicking" noise makes me believe that it's trying to start, but it's not pulling enough amps. Considering everything that you've already replaced, I would start there. Assuming you've already made certain all of your connections are good. Also, make sure the ground wire for your electrical system is good. Not loose, corroded, etc...
You can even call the local golf course and ask to speak to the golf cart mechanic. I would get several calls a week from drivers when I worked as a diesel mechanic.
Oct 20, 2016 • Golf
Troubleshooting gad pedal on electric clubcar
Not sure exactly what you mean. A model number will help so I might look at wiring diagram. Is the pedal a variable speed or maybe about 4 different set speeds? The model number will tell me. First thing to check is the battery terminals for good connection with cables and and make sure cables are clean.
Jul 26, 2016 • Golf
I CONNECTED MY GOLF CART TO THE CHARGER AND CHARGER IT FOR A COUPLE HOURS NOW IT WONT MOVE FORWARD OR IN REVERSE.
Troubleshooting a golf cart - APLawrence.com
aplawrence.com > Miscellaneous
Mar 29, 2015 - If you need help with a golf cart, I suggest asking at Buggies Unlimited. .... Within a half hour I had everything in place, cinched down, connected and ready. ...it is still getting power to the forward and reverse other words itsworking and ... I let mybatteries completely drain and now the charger won't turn on, ...
Put Spring In Your Electric Golf Cart ' Golf Cart Talk Blog
https://www.golfcarcatalog.com/golf-cart.../put-spring-in-your-electric-g...
Mar 9, 2004 - On a car with 8-volt batteries, connect a 12-volt charger to each individual ... If you do not have a 'Regen' system, then just put the Forward/Reverse(F/R) switch into the .... speed controller stays dormant and will not permit the car tomove. ..... My other question would be did anything "fail" in the cart prior to ...
About Golf Cart Battery Chargers ' Golf Cart Talk Blog
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Apr 1, 2012 - Tutorial on golf cart battery chargers, the basics, what goes wrong, ...BATTERIES ARE DEAD AND CHARGER WON'T COME ON ... This is usually indicated by a car that creeps when the brake is off and the car is in forward orreverse. ... a connected pair of batteries with a 12 volt, auto style battery charger.
Basic EZGO Golf Cart Problems And How To Fix
Feb 09, 2016 • Golf
1helpful
Making golf carts faster
if its gas remove govener sping and hook up throttle cable directly to carb. be forwarned that these are not designed for high end speed and it will be squirly. also a lot of parts will wear faster including the engine.i suggest increasing the govenor spring tension by either bendig the bracket a hair or finding a little stiffer spring
Top Golf Experts
Kardoc
ADMIN Andrew
ADMIN Andrew
vince
Are you a Golf Expert? Answer questions, earn points and help others
