Sony Mavica MVC-CD1000 Digital Camera Logo
Posted on Jul 27, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
C 32 01 disc error while taking pictures
Occurred while taking pictures. can not read disc. have turned off and on, removed cd to no avail. new cd seems to work find. would like to access pictures on disc. was not dropped or had excessive vibration when error occurred.
Lawrence Oravetz
Level 3:
  • Sony Master 10,558 Answers
  • Posted on Sep 01, 2016
Lawrence Oravetz
Sony Master
Level 3:
Answers
10558
Questions
Helped
2700103
Points
29284
Close the session on the cd with cd burning software on a PC. you'll be able to recover pictures that way.
3 Related Answers
Anonymous
  • 89 Answers
  • Posted on Sep 23, 2009
SOURCE: All functions except picture taking work on camera
Problem with lens assembly. No user solution. Contact service.
Anonymous
  • Posted on Feb 16, 2013
SOURCE: Disc Error
Download Picasa from Google (Free photo editing software). Upload your photos to Picasa (on your hard drive) via the grey cable (firewire) that comes with the camera. Then swivel the top button to setup and re-format the disk. You will lose all the photos from the disk, but at least you can use it again. Your precious photos will be on your hard drive so no worries!! Then upload your photos immediately to Picasaweb. That way if the computer goes to custard, the internet has the pics online and safe !! Hope that helps
Harrie
  • 6746 Answers
  • Posted on Jan 12, 2015
SOURCE: I am trying to finalize a disc on a Sony Mavica CD-250 and receive the C13:1 error. How can I get the pictures off the disc?
The manual on page 108 says:
So or your disk is dirty, or is is damaged.
The manual is still online:
https://docs.sony.com/release/MVCCD250.pdf
Hi , can you help me, my JVC car CD player doesn't play the cd ,it takes few seconds trying to read and then ejects the disc.
If this is only occuring when you try to play burned discs, try burning them at a slower rate (2x or 4x)
If this is occuring with storebought discs, You'll need to clean your laser lens. Cleaner Cd's are available from pretty much everywhere that sells Discs.
tip
How to use System Recovery console (steps)
Starting a Recovery
Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears.
You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP .
Back to top
Recovery is taking too long
If your computer stops responding after using the recovery program, do the following:
NOTE:If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
1 Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
2 Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
3 If you are using recovery discs, be aware of the following items:
4 If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
5 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
6 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
7 If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
___________________________________________________________________________________________________________________
2 If you are using recovery discs, be aware of the following items:
3 Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
4 You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
5 Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
2helpful
How to do system recovery on compaq presario 5000 windows me
Starting a Recovery Turn on the computer and immediately begin pressing the F10 key repeatedly until a Recovery Screen appears. You can also start a recovery from recovery discs, or from Windows. For more information refer to Performing a Full System Recovery in Windows XP . Back to topRecovery is taking too long If your computer stops responding after using the recovery program, do the following:
NOTE: If the computer appears to have stopped responding after restarting from a recovery, please wait, it may take several hours or longer to complete the initial Windows XP setup process, especially if a recovery was run from a recovery disc set sent by HP. A Standard recovery may also take longer, depending on how many files are stored in user accounts (like in My Documents ).
  1. Exit the stalled recovery process by pressing the POWER button on the PC until the power turns off, this takes approximately five seconds.
  2. Before recovering, disconnect personal media drives, printers, scanners, cameras, camera-type memory cards, and other devices that did not originally come with the PC.
  3. If you are using recovery discs, be aware of the following items:
    • If you created the recovery discs using Recovery CD Creator, be sure to run the recovery from the same drive that you used to create the discs.
    • Clean the discs with a soft, clean, lint-free cloth wetted with distilled water. Wipe from the center of the disc to the outside edge. You may also use disc cleaning kits or disc restoration kits from your local computer store. These kits produce better results than using cloth and water.
    • You may also use available CD/DVD Drive cleaning kits to clean the laser reading lens of the CD or DVD drive.
  4. Try running a full system recovery again from the hard drive by turning the on the computer and pressing the F10 key until a Recovery Screen appears. This performs the recovery from the hard drive.
  5. If the recovery stops when recovering from the hard drive, use the section Disc errors occur during the recovery process to eliminate errors on the drive. Try recovering again after the disk errors are removed.
When a disc is inserted, it won't read it and won't eject the disc
This is a common error ........this error occur due to the internal defect caused by crashes in the cd you used
you can fix this easily don't worry .......... their are repair guide available
click here to download repair guide
Computer does not recognize it as a CD RW drive
When you try to write data to an optical disc, you may experience any of the following symptoms:
* You receive various disc write error messages.
* You experience issues with the drive and the built-in recording feature of Windows XP.
* You experience issues with third-party programs that you use to write data to the disc.
* You cannot read the disc in all versions of Windows.
* You cannot read the disc, or some files on the disk, by using an MP3 player.
* When you add files or folders to a disc that already contains data, some files are lost.
* Recording files to the disc is inconsistent.
* The disc recording operation is consistently unsuccessful.
TROUBLESHOOTING
Troubleshooting specific errors
If you experience one of the following errors, follow the appropriate steps to resolve the error.
* There is no disc in the drive. Please insert a writable CD into drive.
This error can occur if the CD-R drive or CD-RW drive is not recognized as a recordable device. This error can also occur if the device driver has been corrupted. To resolve this issue, see Method 3 in the "General troubleshooting" section and Method 1 in the "Advanced troubleshooting" section.
* Drive not accessible, incorrect function
This error message typically occurs when you try to write to a CD-R or a CD-RW, and the Windows XP built-in disc recording feature does not recognize the CD drive as a recordable drive. This error message may also occur if specific third-party programs are installed. For more information about how to troubleshoot this error,
when you access the CD-ROM drive, the DVD-ROM drive, or the CD-RW drive
* Error Deleting File or Folder.
Cannot delete file name. Files on this CD-ROM drive are read-only. You cannot copy or move files over to this CD-ROM drive.
This error message can occur because individual files cannot be deleted from the CD-RW. You cannot use the CD disc recording feature of Windows XP for random-access storage while you are writing to disc.
To set the service to Automatic, follow these steps:
1. Click Start, click Run, type services.msc /s, and then click OK.
2. Double-click IMAPI CD-Burning COM Service.
3. Under Service Status, click Start.
4. Try to write data to a CD.
Hi, my ps3 wont read bluray discs. I was getting an 800 series error code on the disc startup but now it won't even see the discs. It does see ps1 and ps2 discs, as well as cd's and dvd's. I ordered an...
Hello sir
Here The 800 Series Error Codes :
80029945 - Can’t playback burn BDr movie (error in picture above)
80029946 - Attempting to play burnt Dual layer NTSC disc on a Pal ps3
(workarouns is to transfer files to ps3 via TVersity)
(added 24th Sept 2007)
80029301 - An error occurred during the delete operation (attempting to delete
some ps2 homebrew from virtual mem card) (added 15sept2007)
80029516 - Sign in to PLAYSTATION-Network (needed for some games or Ps3
processes - have to sign in to use them) (added 04-sept-2007)
80710A06 - An error occurred during the install operation (error when downloading
game from PSN - network error occured (added 30thAug2007)
8003041F - An error occurred during the copy operation (using media server) (added
27aug2007)
80010006 - An error occurred during the start operation (added 22aug07 - corrupted
folding install)
80010007 - An error occurred during the start operation (added 17aug07 - during
disc swap tests)
"no disc" error message
Try unplugging the unit, then remove the cover. Take a cotton swab, wet one end with glass cleaner, and clean the lens on the laser assembly. Use the other end to dry it off and finish cleaning. Wipe very gently, do not press down hard on the lens.
This problem is usually (not always) caused by dust and smog accumulating on the lens, preventing the laser from reading the disc. Symptoms are skipping, spinning and not reading, or "no disc" errors.
2answers
CoD4 disc won't read.
how many times have you tried to play the disc?
the 360 is prone to many disc read errors, and most of the time if you just keep trying to play the disc it will work. xbox recognized the problem, and with the new dashboard update you can install games to your hard drive which minimizes the time the disk is spinning, which in turn minimizes disk read errors.
if it doesn't play, I would deffinetly try getting a new copy before sending in the console. getting a new copy is just a trip to the store, sending in the console will take a month.
2answers
Disc won't read
The prob is that your lazer is knackered you will have to replace the lazer on the DVD.
Thanks
3helpful
3answers
Will not read any games. Says it cannot read disc....
First of all, if you just got your xbox, SEND IT IN or TAKE IT BACK TO THE STORE! you will get a FREE WORKING XBOX 360! If you have no warrenty then....
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
