Question about Nikon COOLPIX P80 Digital Camera
Image gets a black surrounded
Display screen shows a black surrounded before going to take snap
Display on screen is small, surrounded by black screen how do I enlarge entire display
Right click the desktop background, and click screen resolution. Move the slider as high as it goes, and click apply.
Apr 07, 2014 | HP Compaq Presario 2500LA Notebook
My camera was dropped. The LCD screen is black with two small crack lines on screen. There are some light vertical lines but no image at all (in camera or playback mode). Zoom moves. I can hear camera...
The screen is fully damaged. You will have to get it replaced. Prior to that click a few snaps and transfer them to yous PC and check whether all the images are sharp and do not show any problem. Cause the service centre might try to get more money from you saying a different problem was found. If the images are fine. dont forget to mention the same to the service centre people.
May 01, 2010 | Panasonic Lumix DMC-ZS3 Digital Camera
Black screen, hear voices , but no picture playing?
check your screen back Light or get a working screen and test it or your screen flax is bad
Mar 31, 2017 | Mitsubishi WD-73C9 73" DLP TV
Can't get a picture on the screen - just shows black. When we turn the camera on the LCD screen displays the function choices and menu options, but will not display any image. If we take a picture using...
Check the SD card, they have sliders on them which lets you "lock" the card so nothing can be put on or taken off of it. Make sure that is off. Then go through the menu on the camera and try to format the card again. If the card is bad it should give you an error message when it tries otherwise you should be good :)
Aug 19, 2009 | Canon Powershot A1000IS 10MP Digital...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open,...
My i85 camera's lcd no longer displays what you are looking at. Just a black screen. All the menu items are there and working. The battery is charged. The power button is working as well as the lens open, but no image is available just a black screen. When I I try to take pic is showed very low light but doen't show image of pic taken when I check. Please advise. This a brand new camera and was taken excellent pic as of this friday. [email protected] Mr.Tracy Johnson
Apr 26, 2009 | Samsung i85 Digital Camera
The display screen will not clear on my FinePix A900
Go to the web site and see if they have a chat with a tech mabey this will help.
Dec 30, 2008 | Fuji FinePix A900 Digital Camera
IBM T40 Laptop screen goes black, will not come back
First of all, you have to check whether you can see video signal with surrounding light tilting the screen.
If you can see dim image, all you have to do is replace back-light inverter or fix it. Usually, the fuse is open and you can connect it by simple soldering.
If you can't see dim image, it is another problems.
Give it a try.
Dec 09, 2008 | IBM ThinkPad T40 2373 Notebook
Display is partially blacked out
From your description sounds like the lcd maybe going out?
May 26, 2008 | Casio Exilim EXZ1050 Digital Camera
While taking smap just blank dark black snaps are coming
This definitely sounds like a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
Here's the official advisory for Asia. You should search www.canon.com to find the local repair center in Bangladesh:
http://www.canon-asia.com/index.jsp?fuseaction=support&prod_type=image-phenomena_notice
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Dec 05, 2007 | Canon PowerShot A95 Digital Camera
It doesn't take pictures...
Sounds like a defective CCD imager. You may be in luck. Canon should fix this for you for free, including free shipping both ways. Please check the following two links for more info:
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Nov 02, 2007 | Canon PowerShot A80 Digital Camera
Nikon COOLPIX P80 Digital Camera Logo
63 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Ekse
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Nikon Camera Expert? Answer questions, earn points and help others
