Euro-Pro Shark by Euro Pro Sewing Machine Logo
Debbie Parker Posted on Jul 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fixing timing on a shark euro pro 9110 sewing machine
My bobbin will not catch and my timing is off.
  • Kevin Scott
    Kevin Scott Aug 14, 2018
    Hello I've got the same problem that you have and much to my dismay there are little to NO helpful videos out there! I've tried multiple ways of wording my search and the results have been hours of watching videos that have nothing to do with my machine at all... I'm taking mine completely apart at this point and just hoping for the best in finding my own solution to this problem.
    Good Luck!!
R.A. Ellis
Level 3:
  • Euro-Pro Master 12,731 Answers
  • Posted on Jul 26, 2016
R.A. Ellis
Euro-Pro Master
Level 3:
Answers
12731
Questions
Helped
2613543
Points
59176
There are lots of web sites and videos explaining sewing machine timing.
sewing machine timing Google Search
How to fix the operation buttons on a 9110 euro pro
check and make sure the bobbin winder has returned to it's normal position for when you sew
My needle is not picking up my bobbin thread. How can I correct this issue?
Could be you are using the wrong needle. If it is too short it will not pick up the bobbin thread. Or your machine could be out of time.
1helpful
The thred keeps jaming in the bobben on my 9110
Check to be sure your bobbin is in correctly. so turn clockwise, others counterclockwise.
What is the name for the case that holds the lower bobbin on the euro-pro 9110? It is made of plastic and sits inside of the needle plate. I need to be replace it but I can't locate the part number...
its called the bobbin case, check these sites for one
sewingpartsonline.com
sewvacdoctor.com
sewingpartsdirect.com
whitesewingcenter.com
sewingsupplywarehouse.com
sewforless.com
some of these site you might have to email & ask them about the part
I need to purchase a needle plate (?) the silver plate covering the bobbin for my Euro-Pro 9110.
try these sites for parts
mastersewusa.com
sew4less.com
sewingmachinestitch.com
sewingcenter.us
I am missing the plate that covers the bobbin, what is it called and where can I get one.
I've check online for different places that have euro-pro parts & here are the websites
sew4less.com
mastersewusa.com
2answers
Shark 9110 won't thread bobbin
The same thing just happened to me, but I am miising a piece that fell off. Make sure there is a little metal wire piece on .the bobbin winder, if not that is your problem
1helpful
Won't catch bobbin thread
In order to see whether or not my euro-pro 9110 had a timing issue, the service rep had me change out the needle (making sure I was using anything but a Singer brand needle--they do not work in these machines). I re-threaded the needle, took out the bobbin casing and the plastic ring encasing the bobbin, then lowered the needle to see if the hook on the metal ring holding the bobbin actually catches the thread on its own. If it doesn't catch, it's a timing issue and needs repair. They can walk you through this process of troubleshooting and set up repair if need. Call Eruo-Pro's customer service center for sewing machine service and repair at 800-798-7395
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
