Dishwashers Logo
G
Gertrude Trainor Posted on Jul 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My GE dishwasher is showing an E8 code...my dishwasher will not start. What can I do?
The dishwasher has an Error Code E8. It will beep when you open and close the door, but none of the other functions work. None of the lights will light up and I can not cancel or start when pushing on the button.
Rocguy
Level 3:
Master:
  • Master 377 Answers
  • Posted on Jul 26, 2016
Rocguy
Master
Level 3:
Master:
Answers
377
Questions
0
Helped
110510
Points
1197
Maybe try unplugging it for a minute or so and plug it back in.
1helpful
2answers
GE window air conditioner showing error code E8
Shery ck here...
https://www.youtube.com/watch?v=K_WWBNEuSnU
also clean the unit... unplug.. spray hose thru the vanes/coils outside/back side to remove dust and dirt from the unit. Let sit for 15-20 minutes before pluging back in.
https://www.youtube.com/results?search_query=clean+window+ac+unit+without+removing
Best to you.
My. GE dishwasher is showing E8 code. What does it mean?
means that the unit thinks the water coming into it isn't hot enough. It can be reset, but here is the way to avoid this problem. Run the hot water in the sink until it comes out hot. Then the unit shouldn't give this error.
All dishwashers require at least water of 140 degrees or higher
1helpful
Where is the distributary valve?
that is a very good question
i cant find a "distributary valve" for sale
lots of water inlet valves hot and cold single units
almost every dishwasher user manual and has code e8 mentioned and faulty distributary valve
why the fault
.If the distributary valve have worked for 150
seconds, and could not reach right
position during wash cycle,after the cycle is finished, the dishwasher will shut off all
loads, the alarm buzzer will ring for 30 seconds and the window will display "E8" at rate
of 1Hz in 30 seconds, and then display "E8" , drain water for 2 minutes meanwhile
May 12, 2016 • Dishwashers
Error code E8 appears mid wash, heater is working ok, machine has been hooked up to the hot water instead of cold. I have since directed cold water through water valve.
hot water form the house takes less power to bring up to machine temperature so by hooking it to cold water will increase the power consumption
call a service center and get the explanation for the error codes and that will explain what is faulty
you didn't mention the make and model of the unit and every error code appears different
for example in a fulgor milano machine code 8 is failure of orientation of distributary valve ===causes open circuit or break of distributary valve
for hoover nextra e8 is dishwasher has failed to heat with water in a reasonable time or has failed to detect the water heating element===causes check water heating element/wiring--check wiring to main control module
go google and type in-- dishwashing machine error code 8-- and see if there is any site for your machine to get the error code and causes
other than that get in a service technician for a correct diagnosis and fix
Apr 23, 2016 • Dishwashers
1helpful
Display shows error code "F1"
F1 Failed Thermistor Control Replace Electronic Range Control (ERC)
Good Luck and Please Rate Fixya!
4helpful
Error code: "Ih" on GE Triton XL. What is reset combo?
After leaving the dishwasher locked with the error code still showing, I returned to find that it had reset itself and run through the full cycle.
Problem solved itself.
GE FTP18
I have the same problem, although my oven is 3 years old. I am having the door latch replaced today. cost $240. The repair company that I contacted sid that these ovens are their bread & butter!!! If I could afford it I would ship all of my GE appliances(which are only 3 years old mind you) to them and tell them to shove them!! I alreadt spent over $200 on my GE dishwasher which at the time was only 1 1/2 yearsd old.Did you clean the oven before the error code started [email protected]
Top GE Dishwashers Experts
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
