SOURCE: black vertical line on p42w34p plasma
could be a loose ribbon cable on a buffer board, or one of the buffer could be going bad
SOURCE: SVA plasma tv-model# HD4208T
you can get a manual for your tv at wwww.partstore.com that will guide through the setting up of your tv,good luck.
SOURCE: No sound on some channels
Check in the menu to see if the audio is on SAP. If it is change it to Stereo. Hope this helps
SOURCE: Channel Scan on my Philips 26" TV only finds the local channels.
Hi.
you should go into your tv's setup menu and go to the tuner settings and make sure it is set to CATV (cable tv) and not Antenna/Air also splitting a cable to many times can cause the signal to weaken and gain a lot of noise/distortion that could be an issue that can only be solved by having the company come to the house and do a test ALSO when your in the tuner menu in under your tv's setup menu try adding a non local channel manualy and then see if the tv will tune to it, if so then you might have to add them manually at the worst... my guess is that it is not set to CATV/cable tv hope this helps and if not i hope someone else can.
SOURCE: the sylvania plasma tv does
You just can't. Not without an external receiver.
Your TV is simply missing a piece of hardware - it is called TUNER - that can understand the signal that runs through the cable (or an antenna) and decode it into simple video signal.
So the only solution is to buy an EXTERNAL TUNER device (also called external receiver or external set top TV box).
Those are rather cheap compared with what they used to be, but if you care for an advice from professional it is: sell your TV and use the revenue towards the purchase of a new one. All TVs currently in the mainstream sales channels have that thing built-in.
Some of the older models that you will find on Craigslist (like yours) do not.
it is usually not a problem for users with cable TV because most cable TV boxes also have a built-in tuner. If you are talking about how to connect your TV to your local cable company then the right thing to do is call your cable operator and tell them you want a newer receiver that outputs standard composite (one yellow one red one white) or component (green, blue, yellow and white and red) - if your TV has the later.
Hope this helps. If it does please rate accordingly.
Cheers,
www.coppelltvrepair.com
